I am trying to drive an electrical vacuum pump from a car directly from 12 VDC.
Earlier, I succeeded with a different pump just by connecting them to DC power, the other pump (different brand) used around 10 A at 13.8 V.
But now I got a new pump (different manufacturer) which does not rotate when I plug the power. It just moves small steps each time I connect it.
It might be an AC pump, which seems strange to me for using it in a car. Can someone help me understand how to drive it?
I attach the image of the circuit inside after opening the cap in the electric side, next to the two leads.
The model of the pump is 59220-J5000. It looks exactly like this.. The resistance between the leads is about 0.2 ohm.
the circuit of the pump
    \$\begingroup\$ Very nicely built inside, apart from that the photo is useless. Link a product description. It seems DC to me. \$\endgroup\$ – Marko Buršič Feb 26 '20 at 22:55
  • \$\begingroup\$ Could you attach a picture of the nameplate? \$\endgroup\$ – bitsmack Feb 26 '20 at 23:03
    \$\begingroup\$ probably you need a stronger power supply, that's usually the problem when I connect a motor and it just twitches. connect a small lamp (orr led ans resistorm, or voltmeter) to the power supply and connect the motor in parallel. \$\endgroup\$ – Jasen Feb 27 '20 at 4:12
    \$\begingroup\$ stall curren is typically 10 times run current, so 30A may not be enough. possibly test by connecting it to a car battery. what is the DC resistance of the motor? \$\endgroup\$ – Jasen Feb 27 '20 at 4:17
    \$\begingroup\$ So 60 A stall current at 12V you need a power supply that can briefly provide that sort of current, maybe adding some ultracapacitors in parallel with your supply could help. \$\endgroup\$ – Jasen Feb 27 '20 at 4:27
Jasen provided the correct answer in the comments: the original power supply could not provide the initial current to start the motor. After switching to a more powerful (108 A, 30 V) power supply, the pump started properly.
