I recently purchased this item to use with an arduino:
http://www.sparkfun.com/commerce/product_info.php?products_id=9105
My problem is that I realized after the fact that this wasn't attached to the breakout board. Are these connections too small to be soldered by hand? What is the smallest distance between connections that can realistically be soldered by hand?
I don't have any problems hand-soldering connectors like that. I use a Metcal soldering station with a mini-hoof cartridge. I tack the connector down at two opposite corners, making sure it is positioned properly using a stereo microscope, apply plenty of jelly flux, and drag-solder each row.
  • \$\begingroup\$ But not many people have such expensive equipment... \$\endgroup\$ – JvO Jan 19 '17 at 19:40
  • \$\begingroup\$ It wasn't expensive: I bought my Metcal system second-hand for £120 and my microscope cost me £65. \$\endgroup\$ – Leon Heller Jan 20 '17 at 8:24
