First of all, an honest warning - I am a brave (and stubborn) idiot, and a self-taught idiot to boot. I know my way around the basics and have repaired some non-trivial circuits (various complex acid-damage trace repair and diagnosing a partial short on a RAM address line of a pinball CPU board) but essentially, I am learning electronics completely backwards and learning about things after I need to know them to complete a repair. My formal background is software programming and I'm learning the hardware side of life as a very useful (and fun) hobby.
Of course, this 'learn backwards' approach is not great but it's okay for most kinds of devices and designs I run into. Except now, I've smashed into the learning curve... well, learning wall that are crystal oscillators. I'm a bit stumped.
For the actual problem, I'm attempting to repair an old CRT, a Panasonic WV-CM1000. It's not especially great but it's a cute, small CRT with great picture quality for what it does. I'm repairing a fault in it not because it's economical, but as a point of pride and a learning experience.
The fault is that for NTSC video signals, it normally supports the very common 'normal' NTSC with a 3.58MHz subcarrier, and the weird type of NTSC that uses a 4.43MHz subcarrier instead. PAL signals and NTSC 4.43 signals work perfectly on the monitor. Plain NTSC signals do not show any color. Support for NTSC 4.43 or 3.58 is selected via a physical switch on the back of the monitor.
I have the service manual for the monitor and I've worked out that changing the NTSC mode with the switch logically swaps out the crystal used to generate the 3.58MHz and 4.43MHz frequencies. The 3.58MHz by all means I could observe (I quickly learnt the hard way how tricky it is to actually test a crystal without changing its behaviour) was completely dead. All load capacitors, resistors etc. appeared to be identical between the two - save for some extra circuitry that enables the 4.43MHz crystal regardless of NTSC mode selected when the CRT is receiving PAL video. Specifically these are two-pin HC49/U crystals.
The obvious and idiot test to do that would confirm it was the crystal and not any other part of the supporting circuitry - or the auto-PAL-selection circuit - was to just physically swap the crystals and change nothing else. That actually worked in that now PAL and NTSC 4.43 signals lost color, and 'NTSC 3.58' mode was now displaying color as if it was NTSC 4.43. Which means 'psychedelic and totally wrong for normal NTSC.'
I ordered some replacement 3.58MHz crystals - same form factor, 'fundamental' operation and not 'overtone' operation and I thought totally appropriate. Dropped one in circuit and... nothing. No effect. The new oscillator is not oscillating. Old one still wasn't, either.
Touching between the video processing IC and the crystal with anything metal coaxes out some partial, very incorrect color operation, but I know this could be any number of side effects I'm introducing into the circuit that is making the crystal partially oscillate.
From what little I understand, my replacement crystal is not close enough to original specification and I need to make adjustments to suit the new crystal. The below schematic is the relevant portion of the whole thing. The signals from the other side of the diodes come a mess of circuitry that includes the selection switch, the color and brightness knobs, and obviously the video signal itself. The crystals are connected to pin 16 of the LA7680 video IC, which is (obviously) the XTAL pin. X202 was dead and is still dead with a new crystal. X201 works happily sitting in X202's place.
So my questions are:
- What is the general workflow for replacing a crystal in an existing circuit with another one - what adjustments should I be making to existing parts?
- Am I making some fundamental misunderstanding that is obvious to better educated individuals, so far? Is this repair even sensible? Am I just looking at adjusting the below section of circuit to match the new crystal, do I need to instead provide a better-matching crystal, or am I totally dead in the water without an exact replacement for reasons I'm ignorant to?
Ideally I'd like pointers as to how I should be working this one out for myself - this is no homework question!
