I searched and couldn't find this question in the forum. Maybe because it's so novice:)
I have a pair of XB24 modules. I have connected them both to my laptop through USB adapters. one of these for each of the modules: enter image description here
This is the function set I've flashed into one of them (router AT) and its firmware version. enter image description here
And this is the function set (coordinator AT) and its firmware version for the other enter image description here
These are the settings for the coordinator: enter image description here
and these are settings for the router: enter image description here enter image description here They both have their power level set to 4 (highest) and they are both turned on. But as you can see, router's network address is 0xFFFE which to my knowledge means it's not joined a network. And the communication doesn't take place when I open up two serial connections in XCTU. What am I doing wrong? Is this setup even supposed to work? Any help would be appreciated.
What I had to do was issue (ATRE,ATWR) commands on both coordinator and router. And after setting ID and destination addresses again, I issued a network reset command (ATNR0) on each. then router joined coordinator and serial communication worked without a problem.
