I am creating a simple 4 wheel robot (BO Motors 200 RPM) with Adafruit Motor Shield and Arduino Uno V3. I am trying to use a Bluetooth module to control the robot. However, unlike Mega, I do not have TX1 and RX1 pins on Uno, only 1 pair of TX and RX pins. So, it's a bit difficult to connect the bluetooth module because I realize that it needs soldering, jumper connection won't be possible.
I have following 3 questions. Any help is appreciated.
- Which Arduino pins are actually used by the Adafruit Motor Shield? If I want to do Serial IO through SoftwareSerial, which Digital pins are safe (free/unused) to use?
- If I continue to use the Arduino's Tx/Rx pins instead of using SoftwareSerial via Digital ports, will that be a problem? Are those pins available for use when the shield sits on top of Arduino?
- Following is my code. When the robot runs, I only get one rear wheel running for almost any Serial input. Rest of the motors doesn't run. Will you please take a look at the code and see if anything looks wrong here.
#include <AFMotor.h>
char incomingByte;
int LED = 11;
#define MAX_DISTANCE 2000
#define MAX_SPEED 240
#define COLL_DIST 25
#define TURN_DIST COLL_DIST + 10
// Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor1(1, MOTOR12_8KHZ);
AF_DCMotor motor2(2, MOTOR12_8KHZ);
AF_DCMotor motor3(3, MOTOR12_8KHZ);
AF_DCMotor motor4(4, MOTOR12_8KHZ);
int pos = 0;
int maxDist = 0;
int maxAngle = 0;
int maxRight = 0;
int maxLeft = 0;
int maxFront = 0;
int course = 0;
int curDist = 0;
String motorSet = "";
unsigned long timeNow = 0;
int maxOffsetSpeed = 20;
int right = 0, left = 0, front = 0, back = 0;
int issettings = false;
void setup() {
Serial.begin(9600); // initialization
void loop() {
if (Serial.available() > 0) { // if the data came
timeNow = millis();
incomingByte = Serial.read();
if (issettings == true) {
maxOffsetSpeed = incomingByte;
return;
if (incomingByte == 's') {
issettings = !issettings;
return;
if (incomingByte == '1') {
// front
if (front < MAX_SPEED && back == 0) {
back = 0;
front = front + 40;
moveForward(front);
} else if (back > 0) {
front = 0;
back = back - 40;
moveBackward(back);
if (incomingByte == '2') {
// back
if (front > 0 && back == 0) {
back = 0;
front = front - 40;
moveForward(front);
} else if (back < MAX_SPEED) {
front = 0;
back = back + 40;
moveBackward(back);
if (incomingByte == '3') {
if (back > front) {
turnLeft(back);
moveBackward(back);
} else {
turnLeft(front);
moveForward(front);
if (incomingByte == '4') {
// right
if (back > front) {
turnRight(back);
moveBackward(back);
} else {
turnRight(front);
moveForward(front);
if (incomingByte == '5') {
// right
front = 0;
back = 0;
stopRunning();
void moveForward(int speedSet) {
motor1.setSpeed(speedSet + maxOffsetSpeed);
motor2.setSpeed(speedSet + maxOffsetSpeed);
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
motor1.run(FORWARD);
motor2.run(FORWARD); // turn it on going forward
motor3.run(FORWARD);
motor4.run(FORWARD); // turn it on going forward
void moveBackward(int speedSet) {
motor1.run(BACKWARD);
motor2.run(BACKWARD); // turn it on going forward
motor3.run(BACKWARD);
motor4.run(BACKWARD); // turn it on going forward
void turnRight(int speedSet) {
if (speedSet < 200) {
speedSet = 200;
motor2.run(FORWARD); // turn motor 1 forward
delay(200);
void turnLeft(int speedSet) {
speedSet = 200;
motor2.run(BACKWARD); // turn motor 1 backward
motor4.run(FORWARD); // turn motor 2 forward
delay(200);
void stopRunning() {
motor1.setSpeed(0);
motor2.setSpeed(0);
motor3.setSpeed(0);
motor4.setSpeed(0);
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
