How do I choose a proper approach for detecting ground fault currents (20 mA through 30A, 60Hz)? Let's say I have a zero sequence CT and calculate a burden resistor. I have a 12-bit ADC in the micro. I have seen different methods:
  1. A peak detector, like this one
  2. DC biasing like this
  3. Doing some FFT in the micro?
I want to avoid as much hardware as I can and leverage the microcontroller, even for filtering. Also, I don't think a fixed gain amplifier or burden resistor would cover this wide range of current with good resolution?
I'd appreciate your suggestions.
    \$\begingroup\$ Use a GFCI (USA) or an RCD (UK)? \$\endgroup\$ – Andy aka Mar 3 '20 at 14:35
-1
I dont have reputation so i could not able to comment. The most common way is using fuse.But the circuit stops working if fuse breakes .
Do you want to detect the false currents ? or do you want to detect and eliminate or suppress?
For ac circuits you can use bypass capacitors , it short circuits during high frequency.
