I need clarification regarding comparators with internal Hysteresis.
I have a comparator with internal Hysteresis “X” mv and I am using external feedback resistors to create a hysteresis of “Y” mv.
Will the total hysteresis be “X+Y” mv?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI need clarification regarding comparators with internal Hysteresis.
From Maxim note:
Hysteresis is designed into most comparators, usually with a value of 5mV to 10mV. Internal hysteresis helps the comparator avoid oscillation due to small amounts of parasitic feedback. Though sufficient to prevent the comparator from self-oscillating, such internal hysteresis can easily be swamped by any external noise of greater amplitude. In that case, you can improve performance by adding hysteresis externally.
