According to chapter 21 of Electronic Principles(8th edition), the Wien bridge oscillator uses the Johnson-Nyquist noise from one of the resistors as the startup voltage. It selects for a desired harmonic and amplifies it. Some schematics show a Wien bridge oscillator using a tungsten lamp as a source of resistor noise. Now is this also true for the phase shift oscillator? This seems quite different from other oscillators which use the rising voltage on a capacitor connected to the DC power supply to build up oscillations. Part of this question is based on the fact that neither the Wien bridge oscillator nor the phase shift oscillator have inductors.
  • 6
    \$\begingroup\$ The tungsten lamp is NOT used as a noise source. It is used as a temperature-variable resistor to stabilise the loop gain to precisely 1 to sustain the oscillation without letting it increase to the clipping point (which introduces unwanted harmonic content). It is a fairly unique non-linear element in that it is very nearly linear at oscillation frequencies because of the thermal time constant of the filament. \$\endgroup\$ – user_1818839 Mar 3 '20 at 21:35
  • \$\begingroup\$ "Wien Bridge oscillator" is a positive feedback circuit. The reaction is stabilized by a nonlinear element in the negative reaction path with the "ad-hoc" gain. \$\endgroup\$ – Antonio51 Jul 10 at 13:26
Before Johnson noise ever kicks a Wien bridge into action, the sheer monstrous transient of applying power does the job.
It may look like that but almost certainly (as certain as I can be without the schematic you saw) the lamp is there to provide non linear gain so that the peak to peak amplitude doesn’t crash into the power rails.
You seem to be describing a Schmitt trigger single RC oscillator. It doesn’t use phase shift at all. It uses thresholds and the charging time of the capacitor to dictate oscillation frequency. Go look up relaxation oscillators.
These type of oscillators rely on the changing phase shift of a network of resistors and capacitors to produce a phase shift of 180 degrees at one particular frequency. At different frequencies, the phase shift is not 180 degrees and hence, when wrapped around an inverting op-amp, won’t oscillate.
In fact oscillators like the Colpitts (that use an inductor) hardly ever oscillate at resonance because the phase change at perfect amplitude resonance just isn’t right for sustained stable oscillation. Taking this further, hardly any (if any at all) oscillators use perfect amplitude resonance. Try googling Barkhausen stability criterion for oscillators.
Whether the oscillator is Wien bridge or phase shift or, "so-called" resonant oscillators like the Colpitts, Hartley or Pierce, the guiding principal is that of providing the right phase shift to produce a stable oscillation.
