I've looked at some other forums and know that this type of error occurs when multiple outputs drive the same input however I am struggling to see how to fix this error and what specifically is causing it within my code. For context, the code that I am attaching is a submodule that is instantiated in a top traffic light controller module. The purpose of this module is to control what state the traffic light controller is in (Green_red, yellow_red, red_green, and red_yellow). The code that I wrote works when I simulate it with a testbench, however, I keep getting the same errors. There are two other submodules that have the same errors that I didn't attach, however, they follow the same exact logic as the car module just for the different inputs.
This is my code for the top module:
module Controller (clk, rst, c, e, p, SCL, SVL, current);
input clk, rst, c, e, p; //Clock, reset, and sensors
output reg [2:0] SCL, SVL; //Lights for Santa Clara and Seventh. 100 is green, 010 is yellow, and 001 is red
output reg [1:0] current; //Current state
wire [1:0] c_current, e_current, p_current;
wire c_served, e_served, p_served;
wire c_begin, e_begin, p_begin;
wire [2:0] f_reset; //Forced reset for when multiple sensors are detected at same time. 100 is for car, 010 is for emg, 001 is for ped
reg [2:0] forced;
assign f_reset = forced;
parameter SCG_SVR = 2'b00, // Santa Clara green, Seventh red
SCY_SVR = 2'b01, // Santa Clara yellow, Seventh red
SCR_SVG = 2'b10, // Santa Clara red, Seventh green
SCR_SVY = 2'b11; // Santa Clara red, Seventh yellow
initial //Default conditions
begin
current = SCG_SVR;
SCL = 3'b100;
SVL = 3'b011;
end
Car carl (clk, rst, c, c_begin, c_served, c_current, f_reset);
Emergency emg1 (clk, rst, e, e_begin, e_served, e_current, f_reset);
Pedestrian ped1 (clk, rst, p, p_begin, p_served, p_current, f_reset);
always @(posedge clk)
begin
if (c_begin && ~e_begin) //Car has 2nd priority, occurs whenever emergency is not detected
begin
current = c_current;
forced = 3'b011;
end
else if (p_begin && ~e_begin && ~c_begin) //Pedestrian has least priority, occurs whenever emergency and car aren't detected
begin
current = p_current;
forced = 3'b110;
end
else if (e_begin) //Emergency has the most priority
begin
current = e_current;
forced = 3'b101;
end
else
begin
current = SCG_SVR; //Current state whenever nothing is detected
forced = 3'b111;
end
end
begin
if (c_served || e_served || p_served) forced = 3'b000;
end
begin
case(current)
SCG_SVR:
begin
SCL = 3'b100; //Santa Clara green
SVL = 3'b001; //Seventh red
end
SCY_SVR:
begin
SCL = 3'b010; //Santa Clara yellow
end
SCR_SVG:
begin
SCL = 3'b001; //Santa Clara red
SVL = 3'b100; //Seventh green
end
SCR_SVY:
begin
SVL = 3'b010; //Seventh yellow
end
endcase
end
endmodule
This is my code for the sub module:
module Car (clk, rst, c_reqd, c_beg, c_srvd, current_state, f_reset);
input clk, rst, c_reqd; //Clock, reset, car requested
input wire [2:0] f_reset;
output reg c_srvd = 0, c_beg = 0; //Car served, car began
output reg [1:0] current_state;
reg [1:0] next_state;
assign forced = f_reset;
integer counter = 0;
begin
next_state = SCG_SVR;
end
always @(*)
begin: CFSM_seq
if (rst || f_reset[2] == 1)
begin
counter = 0;
end
else current_state = next_state;
end
always @ (posedge clk)
begin: CFSM_comb
case(current_state)
SCG_SVR:
begin
if (c_reqd)
begin
next_state = SCY_SVR;
c_srvd = 0;
c_beg = 1;
end
else
begin
c_srvd = 0;
c_beg = 0;
end
end
SCY_SVR:
begin
if (counter < 4)
begin
counter = counter + 1;
end
else
begin
next_state = SCR_SVG;
counter = 0;
end
end
SCR_SVG:
begin
if (counter < 10)
begin
end
else
begin
next_state = SCR_SVY;
counter = 0;
end
end
SCR_SVY:
begin
if (counter < 3)
begin
if (counter == 1)
begin
c_srvd = 1;
end
end
else
begin
counter = 0;
end
end
endcase
end
endmodule
And these are some of the errors I'm getting:
[Synth 8-6859] multi-driven net on pin carl/next_state[1] with 1st driver pin 'carl/next_state_reg[1]__0/Q'
[Synth 8-6859] multi-driven net on pin carl/next_state[1] with 2nd driver pin 'carl/next_state_reg[1]/Q'
[Synth 8-6859] multi-driven net on pin carl/next_state[0] with 1st driver pin 'carl/next_state_reg[0]__0/Q'
[Synth 8-6859] multi-driven net on pin carl/next_state[0] with 2nd driver pin 'carl/next_state_reg[0]/Q'
[Synth 8-6859] multi-driven net on pin carl/counter[31] with 1st driver pin 'carl/counter_reg[31]__0/Q'
[Synth 8-6859] multi-driven net on pin carl/counter[31] with 2nd driver pin 'carl/counter_reg[31]/Q'
[Synth 8-6859] multi-driven net on pin carl/counter[30] with 1st driver pin 'carl/counter_reg[30]__0/Q'
[Synth 8-6859] multi-driven net on pin carl/counter[30] with 2nd driver pin 'carl/counter_reg[30]/Q'
//multiple more of the same errors with car1 and counter[n]
