So here is the problem:
First, I have a door opener device that gives me one wire to control it. This wire should connect to ground so the device works. We do not want to make the door opener to work all the time, obviously.
Second, I have a device for remote control, when a button is pressed on the remote, a ground signal is output on the box for a couple of seconds. This is the only output of the controller and unfortunately It can't serve as a ground to the door opener. It has simply too much impedance to make the door opener work. It works with lighter loads such as leds. Unfortunately I cannot change this control I'm treating it as a "black box".
What I need help with is figuring out a way to use the controller wire as a "trigger" to activate the door opener.
Summing up:
Both devices use a 12v power supply
Door opener wire (should connect to ground)
Controller wire (ground signal)
