I'm trying to tap into my car's brake circuit to switch between receiving a wireless camera signal and powering my device. For this purpose, I connected a relay to the circuit via a fuse tap. It should connect the phone to the receiver (displaying the camera feed) when the brakes are applied and charge the phone otherwise. Unfortunately, I'm having some difficulty figuring out how to get the relay to switch properly.
I wired the relay to the circuit in the fuse box that powers the car's instrument lights and the brake lights. The current draw for the instrument lights (which are always on) is 0.7 amps. The brake lights draw 1.15 amps. Without adding additional resistance between the car battery and relay the constant 0.7 amp draw will always keep the relay in the ON position (connecting phone and receiver). Hence, the need for additional resistor between battery and relay. The relay's coil draw is .5 amps.
Here is my most likely flawed resistor calculation. Please point out any errors.
First I calculate the internal circuit resistance
V=IxR
12 = .7xR
R = 17.143 ohms // with the brake lights off
12 = 1.15xR
R = 10.169 // with brake lights on
To keep relay in OFF position, I need to supply a current less than the relay's coil draw (.5 amps). Adding an 8 ohm resistor should do the trick:
R = 17.143 + 8 = 25.143 //brake lights off
I = V/R
I = 12/25.143
I = .477 < 0.5 // relay switch in off position
R = 10.169 + 8 = 18.169 // brake lights on
I = 12/18.169
I = .66 > 0.5 // relay switch in on position
It seems like 8 ohms is enough to keep switch OFF with 0.7 amp draw, but my relay always stays in the ON position, even after I increase resistance to 16 ohms. So what gives?
    \$\begingroup\$ If your circuit drawing is correct, you don't size that resistor based on the current drawn by the rest of the circuit, you must size it based on the rated current and voltage of the relay. It isn't clear what you want the circuit to do. At what times do you want the relay to be closed and at what times open? It isn't clear why you are mentioning the current drawn by your lighting circuits and how that would relate to controlling the relay. It looks like you want to connect a phone to either a 5v power supply or a "receiver" but it is not clear what a "receiver" is. \$\endgroup\$
    – K H
    Mar 5, 2020 at 22:41
    \$\begingroup\$ Why do you need that resistor, at all (in few words)? Can you describe a problem in few words, only? \$\endgroup\$ Mar 5, 2020 at 22:43
    \$\begingroup\$ Why not just wire a 12-volt relay directly across one of the brake lamps? \$\endgroup\$
    – Transistor
    Mar 5, 2020 at 22:46
    \$\begingroup\$ @st4rgut - "I have a relay that needs to switch on whenever brakes are applied in my car." If that is the problem which you want to solve, why not drive that relay's coil from the wire which activates the brake lights? As far as I can tell, your question seems to describe an overly-complex approach to a simple problem. Can you please explain why that simple approach I've described won't work for you? \$\endgroup\$
    – SamGibson
    Mar 5, 2020 at 22:47
    \$\begingroup\$ To clarify, I'm asking you to clarify. Edit your question to include your goal, specifically say "I'd like to connect the phone to 5v when X and I want it connected to my receiver when Y". It looks like you want to connect a usb port on the phone to power or the stereo receiver(?). Is this because you have a phone with no microphone jack perhaps? 30A is probably how much current the relay is rated to switch, but how much current is the drive coil rated for? Chances are you don't need a resistor, but you want to connect the relay to something that will switch it at certain times. \$\endgroup\$
    – K H
    Mar 5, 2020 at 22:59
If the car is set up like this:
And you want to tap into the fuse and make it like this:
Then it would make sense that once you reduced the voltage through the circuit enough, by dissipating the power through R1, then the relay would turn off.
The problem is probably that the Relay doesn't require 500mA to switch but uses 500mA at its operating voltage. As the voltage decreases to turn the relay off it probably switches at a voltage threshold much lower than its operating voltage and thus a much lower current draw.
In theory, it would work with a high enough value resistor. But the lights will be very dim, you will burn a lot of heat through the resistor, and the relay won't last as long being partially energized all the time.
You would be better trying to connect the relay in parallel with the rear brake light or at least in series with only the rear light. If connecting to the fuse is the only option then putting a current sensor in series with the fuse and triggering the relay with an MCU (which reads the current value) would be the best option.
  • \$\begingroup\$ Thank you for schematics and explaining why my setup didn't work. I will try wiring the relay in parallel with wires going out from the brake switch as others suggested. Since this answer gave a complete explanation I made this the accepted answer. \$\endgroup\$
    – st4rgut
    Mar 6, 2020 at 4:06
  • \$\begingroup\$ circuit 2 could work if a current relay was used (perhaps 20 turns round a reed switch). the resistor does nothing to help. it's not going to work with a potential relay (the common type) \$\endgroup\$ Mar 6, 2020 at 22:25
Operate the relay from the signal/voltage that powers the brake lights. This gives 12V when operated and open circuit (= 0V) when off (OR ground when operated and open circuit when off in some less usual situations).
The 12V power line from the battery will remain at about 12V at all times under all usual loads except starting. The starter motor MAY load the 12V line down to 10V or less, but nothing else will.
In a brake light circuit the fuse is typically before the brake light switch, by tapping the voltage at the fuse box you won't get a useful answer.
Easisest is probably to tap the voltage after the brake light switch, on most cars this is somewhere near the brake pedal lever, but some use a pressure switch on the hydraulic brake line.
