I understand that the thickness of a wire affects the resistance of a wire and thus the current flowing through it, and this in-turn would affects the magnetic field.
If I am able to supply the same amount of current through the two wires of different thicknesses, in theory, I should be able to witness the same magnetic field from both of the wires, right?
Can I say that only current affects the magnetic field and not the thickness?
So, can I say that only current affects the magnetic field and not the thickness?
This is only true in relation to the external magnetic field produced "outside" a conductor. For example: a 1 mm diameter wire will produce the same flux density at a distance of (say) 100 mm from its wire centre as a 10 mm diameter wire carrying the same current.
AC considerations
With AC this is also true but, due to skin effects, the thicker wire has less inductance. Because skin effect causes current crowding at the wire surface, the same flux density will be seen at any distant point compared to a thinner wire carrying the same current.
Consider also a conducting tube: if we compared a solid 10 mm diameter wire with a 10 mm diameter hollow tube then, for the same current, the external flux density fields will be the same at any distant point.
Example - Coaxial conductors
This is admirably demonstrated by a piece of coax wire. The inner wire is thin and carries the same magnitude current as the outer shield but, the current directions are opposite and so, we expect fluxes from each to cancel. And this is what we get: the magnetic field produced by the inner wire current is totally cancelled by the returning current flowing back through the shield. This field cancellation occurs anywhere outside the coax cable and proves the point.
Outer shield inductance: -
Between inner and outer shield there is a magnetic flux and, its presence has an interesting knock-on effect - because any current tube (aka coax shield) cannot produce flux internally, all the flux within the coax cable must come from the inner conductor. Given that the flux external to the shield is cancelled to zero, we can rightly say that the shield has zero inductance.
  • \$\begingroup\$ I should have mentioned that DC was under consideration. Nonetheless, interesting features to note in an AC. Thank you. \$\endgroup\$ Commented Mar 9, 2020 at 12:01
  • \$\begingroup\$ @kasekaiser1298 given that the question and answer is 6 days old I think it's unlikely you'll be getting more responses so, you should consider formally accepting this answer unless of course, there is anything you wish to clarify? \$\endgroup\$
    Commented Mar 9, 2020 at 12:19
  • \$\begingroup\$ haha, yes It did answer my question. Thanks again. \$\endgroup\$ Commented Mar 9, 2020 at 15:41
-2
Yes, thickness of wire affects the magnetic field.
Current is inversely proportional to resistance.
Resistance is inversely proportional to area of cross section(thickness).
So, current is directly proportional to area of cross section (thickness).
Also, magnetic field is directly proportional to current.
Therefore, magnetic field is directly proportional to area of cross section (thickness)
    \$\begingroup\$ Hi, welcome to the site. While true, this isn't really answering OP's question, which posited a constant current. \$\endgroup\$
    – Matt S
    Commented Jan 25, 2023 at 17:43
  • \$\begingroup\$ I have solved it by taking voltage to be constant. Since in most cases voltage is kept constant only resistance and current changes. \$\endgroup\$
    – Anonymous
    Commented Jan 26, 2023 at 7:56
