I'm trying to interface with an MCP40821 using SPI from an AVR. Using these pin maps:
#define SCK     PB7
#define MOSI    PB5
#define CS      PB4
#define LDAC    PC7
With these register settings:
void SetupSPI()
    DDRB  |= true << SCK | true << MOSI | true << CS;
    DDRC  |= true << LDAC;
    PORTC |= true << LDAC;
    PORTB |= true << CS;
    SPCR  |= true << SPIE | true << SPE | true << MSTR | true << CPOL | true << CPHA;
    SPSR  |= true << SPI2X;
I'm then transmitting the data using a buffer and an interrupt.
#define SHDN    12
void SendSPIData()
    if (SPIBytesTransferred < SPIPayloadBytes)
        SPDR = SPITxBuffer[SPIBytesTransferred++];
    else
        DACReady = true;
void SetDAC(uint16_t value)
    if (!DACReady) return;
    DACReady = false;
    value |= true << SHDN;
    SPIPayloadBytes = DAC_SPI_BYTES;
    SPIBytesTransferred = 0;
    SPITxBuffer[0] = value >> 8;
    SPITxBuffer[1] = value;
    SendSPIData(); //Kick-off transfer
ISR(SPI_STC_vect)
    SendSPIData(); //Send next byte
This all seems to look fine, using my logic analyser I can see the two byte commands go out successfully.
However, the DAC doesn't seem to respond and I'm not sure what else I need to do.
Logic Analyser
  • \$\begingroup\$ Your chip select is always low... some chips (I haven't checked this one) require an explicit down-going edge on their chip select. I would check that first. \$\endgroup\$
    – vicatcu
    Mar 9, 2020 at 18:52
  • \$\begingroup\$ What response were you expecting? And do you need to pulse LDAC according to the (should be linked in the question) datasheet? \$\endgroup\$ Mar 9, 2020 at 18:58
  • \$\begingroup\$ @BrianDrummond I was expecting the DAC value to change, no response back. Will give pulsing LDAC and CS a try tomorrow, thanks \$\endgroup\$ Mar 9, 2020 at 20:16
  • \$\begingroup\$ What's a "MCP40821"? The only hit I get on Google is this very post. MCP4821? MCP4801? \$\endgroup\$
    – Lundin
    Mar 10, 2020 at 7:40
Follow the image below. You need to pulse LDAC and CS needs a falling edge as was stated in the comments.
  • \$\begingroup\$ That sorted it, I thought LDAC was being handled by the peripheral \$\endgroup\$ Mar 10, 2020 at 12:06
