I have a 2N2222A transistor that I use in a circuit coupled with an opamp. Its function is to act as a current booster.
The collector is always supplied with 12V and the emitter can be set anywhere between 0 - 8 V. I was not aware about overheating my transistor, and I believe I've burnt my transistor when I have a current of about 200mA passing through it, when the VC was 12V and VE about 6V.
I want to replace it with one that can handle the power yet not hinder performance. I am also willing to buy heat sinks for the packages.
The range of current I am expecting for this transistor to drive is anywhere between 0 and 300 mA.
I was thinking of this transistor with this heat sink.
  • \$\begingroup\$ Bigger BJT transistors in general need more base current to get the same \$Ic\$. The Beta is only about 30 for this part. While the 2n2222 is closer to 100. You may need to adjust your circuit to account for this. \$\endgroup\$
    – Aaron
    Commented Mar 10, 2020 at 1:03
    \$\begingroup\$ Post your circuit if you want better help. :) \$\endgroup\$
    – Aaron
    Commented Mar 10, 2020 at 1:05
  • \$\begingroup\$ Posted! And thanks, I did not think of that \$\endgroup\$
    – George
    Commented Mar 10, 2020 at 1:08
  • \$\begingroup\$ I believe my op-amp can comfortably deliver 20mA, which would indicate that a B of 30, is more than enough. Right? \$\endgroup\$
    – George
    Commented Mar 10, 2020 at 1:12
  • \$\begingroup\$ @George The D44H11 (NPN) and D45H11 (PNP) can handle a lot of current. Their Early Effect is not so good. But with an opamp there I don't think that's much of an issue (I'm not even looking at your circuit beyond that point, so I'm making no judgments about the topology you have.) And with only 200 mA collector current, you are right that the opamp can drive them. \$\endgroup\$
    – jonk
    Commented Mar 10, 2020 at 1:44
4 Answers 4
Specs:
Input: 12V 0~0.3A
Ouput: 0 to 8V 0~0.3A
Max Case temp rise: 40'C
Speed: not important
Heatsink: 24'C/W convection +X with thermal grease, insulator
Design:
Linear Loss 4V*0.3A = 1.2W
Est: 30'C/W * 1.2W= 36'C rise. OK
WIth 4V > Vce < 12V , the best choice for high hFE is a Darlington TO-220 with this heatsink.
MJD122-1 $0.90 (1) https://www.digikey.com/product-detail/en/stmicroelectronics/MJD122-1/497-16183-ND/3087726
For better linear operation with step load low overshoot, use BJT Op AMP not CMOS R2R type. Even a lowly uA741 would work or LM324. CMOS is prone to high step output overshoot and loads +stray capacitance stability yet C_load are reduced by hFE.
Rs = 1 Ohm means 300 mW dissipation when 100mV will do with 100mV/300mA = 1/3 Ohm or similar with 30 mW. Then change Gain ratio as required.
R6 is redundant relative to R7.
Accuracy depends on tolerance stack-up of all resistors.
For Short circuit protection choose 3V drop R on collector @ 400mA
  • \$\begingroup\$ Remember in future to do at least as many specs before you choose parts as I did. \$\endgroup\$
    – D.A.S.
    Commented Mar 10, 2020 at 3:49
  • \$\begingroup\$ WIll do. Thanks again \$\endgroup\$
    – George
    Commented Mar 10, 2020 at 4:05
first way is to make a Darlington Pair with two transistors. The beta will square, but the voltage drop across the base will be higher (1.4V instead of 0.7V). Just need to recalculate the resistor.
Or you can use 2n4401 (NPN) which here are the specs:
Collector – emitter voltage – Vceo = 40
Vcbo = 60
Collector current Ic – continuous = 600 mA dc
The CENTRAL SEMICONDUCTOR 2N4400 and 2N4401 are silicon NPN transistors designed for general purpose amplifier and switching applications.
  • \$\begingroup\$ I would avoid Darlington here. OpAmp can lose some 2v from + rail (as per datasheet), Darlington can also drop 1.5-2v, 0.2v at R5 and for 8v output the mode will be somewhat marginal. \$\endgroup\$
    – fraxinus
    Commented Mar 14, 2020 at 21:59
The main criteria is a package that can dissipate high power, with a secondary requirement of sufficient current gain to not overload the op amp. So high current handling isn't necessary but good current gain at 300 mA is, which usually means the rated current will be much higher than 300 mA.
The ST13009 has very low current gain due to its high voltage rating (400 volts). A medium power transistor with lower voltage rating such as D44H11 would do a better job. The D44H11 has a guaranteed minimum gain of 60 at 2 A, with typical gain well over 100 at 300 mA.
Next issue is the heat sink. 300 mA x 12 V = 3.6 W. The heat sink you chose has a thermal resistance of 24 °C/W, so at 3.6 W its temperature would rise by 24 x 3.6 = ~86 °C above ambient. That's hot enough to boil water and burn you. In an enclosed space it would get even hotter. A larger heat sink with lower thermal resistance would be safer, eg. V2006B or V6560Y which are both 7 °C/W.
  • \$\begingroup\$ Thank you for your answer. I will consider this! \$\endgroup\$
    – George
    Commented Mar 15, 2020 at 17:11
-1
... (voltage at collector - voltage at emitter) * ( Collector Current) ... ... if you wanna get really technical (Vce)(Ic)+(0.7)(base current) ...
... for your case (12V-6V)(300mA) = 1.8W ...
... (300mA)/(Beta = 100) = min base current of 3mA ...
... There is no issues with the Op Amp, a LM358 can do the job; the issue with your circuit is simply the power dissipation in the tranny
  • \$\begingroup\$ ... Your answer ... will make ... more sense ... if you write proper sentences ... with standard English punctuation. \$\endgroup\$
    – Transistor
    Commented Nov 17, 2020 at 9:46
