I ran across some code that is being used to create a 1ms timer in polling mode, not interrupt mode. However, I'm having a hard time wrapping my head around the function.
So the Systick is configured like this:
Systick->LOAD = 19999UL;
Systick->VAL = 0UL;
Systick->CTRL = Systick_CTRL_CLKSOURCE_Msk | Systick_CTRL_ENABLE_Msk;
So this makes sense. The systick is configured for a 1ms reload value (processor system clock is 20MHz). The systick is enabled but not setup for interrupts, but rather polling.
Now is where I get confused. The following code handles the polling of the systick register:
if(SysTick_CTRL_COUNTFLAG_Msk == ((Systick->CTRL) & Systick_CTRL_COUNT_FLAG_Msk))
Systick->CTRL |= Systick_CTRL_COUNTFLAG_Msk;
Timer_ms++;
So I'm confused about the line
I don't understand why this line is there. When you read the control and status register, the countflag bit resets according to the spec. So why is the code setting the bit to 1 after it was already 1 and reset via the read?
Thanks.
