I've created a 1 channel EEG using the AD620 instrumental amplifier and various active band filters. To add more channels, would I need one instrumental amp and series of filters per channel? or can I use one instrumental amplifier to amplify multiple signals?
1 Answer
You can of course use a single amplifier for all your signal of a single channel, if you apply your band-filters afterwards. You'd need to model where in your device noise appears to see whether that has any downsides.
You of course can't amplify different channels coming from different sensors with the same amplifier. How would you separate two signals that you've added up?
Also, "multiple active filters" very much sounds like a design anachronism: We've had computers fast enough to process EEG signals for about 40 years now. A bank of filters can very well be implemented in software – and it's way easier than building a bank of analog active filters. All you'd need is an analog anti-aliasing filter, so that you can throw an ADC at your analog signal, for example a soundcard.
\$\begingroup\$ I'm confused, you said "You can of course use a single amplifier for all your signal" and "You of course can't amplify different channels coming from different sensors with the same amplifier." What do you mean by the first phrase? \$\endgroup\$– ZenSoloCommented Mar 11, 2020 at 13:02
\$\begingroup\$ I read your question such that you're applying multiple filters to a single channel. You can amplify that channel with a single amplifier before feeding it to multiple filters. \$\endgroup\$ Commented Mar 12, 2020 at 7:52
\$\begingroup\$ I'm already doing that with the instrumental amplifier \$\endgroup\$– ZenSoloCommented Mar 12, 2020 at 12:53
\$\begingroup\$ It's just that a lot of tutorials I've seen online say that I can add more channels to the EEG just by buying electrodes, no other parts, so I don't see how you can use a single intrumental amplifier to handle multiple channels \$\endgroup\$– ZenSoloCommented Mar 12, 2020 at 12:54
\$\begingroup\$ notice that I explicitly didn't say channels. \$\endgroup\$ Commented Mar 12, 2020 at 13:08
