I have a composite polymer material with injected conductive particles inside it, making it a not-so-perfect conductor. I have also fabricated a simple dipole antenna using the wires made of the composite, and it is radiating at 2.4GHz without any problems. Checked with a network analyzer.
I have also tried to simulate it using CST microwave simulation software, but since the material is "home-made" and not defined in software material library, I have to define it by myself by specifying the conductance of the material and define it as a "Lossy metal".
For this, I tried to measure the DC resistance of the material and calculated conductance from it, which shows relatively high resistance and therefore low conductance. I also tried to simulate it with the values that I got from the measurement but there was no luck and it acted like a normal dielectric without any radiation.
The material looks resisting in DC but conducting as a 2.4GHz dipole antenna?
Am I doing something wrong? or forgot something? And what should I do to simulate accurately?
