Can I use 2.5kW solar panels (10x 250 watts) to power a 2kW rated grid tie solar inverter? Will anything blow up?
Panels: 10x 250W, 36V panels
Inverter: 2kW with max input voltage: 500V
Any help is appreciated.
Yes, you can.
Most of the time, the panels won't be generating 2.5kW anyway. But on a really sunny day, the inverter will only draw as much power from the panels as it can process.
