I want to sample an external, possibly very short interrupt signal in my FPGA softcore. I did some research in some digital logic design books, and found this solution, where A is the input signal. The problem here is that it is way too short to be sampled by the synchronous flipflop shown, so a latch is used:
I am now wondering how this can be implemented in Verilog for use in a FPGA, I do not know how to tell the synthesis tool to place a latch there. How can this be done? Also, the design doesn't show how to reset Q - in the plot, it stays high for the rest of the example. How do I reset the whole design to be ready for the next interrupt signal?
Additionally: Do I need to put this signal through a few chained flip-flops to combat metastability, or is this design safe as-is?
  • \$\begingroup\$ You could instantiate the gates directly. \$\endgroup\$ Commented Mar 13, 2020 at 19:36
  • \$\begingroup\$ Do not fail to run any asynchronous external signal through a chain of at least two flip-flops/registers before using it with anything that runs off the FPGA clock. \$\endgroup\$
    – DKNguyen
    Commented Mar 13, 2020 at 19:51
  • \$\begingroup\$ That's true for signals that are longer than your clock period. But OP's problem is a bit (no pun intended) different. \$\endgroup\$
    – SteveSh
    Commented Mar 13, 2020 at 20:09
  • \$\begingroup\$ @SteveSh Yes, I was just looking at it again just now thinking it might be okay. \$\endgroup\$
    – DKNguyen
    Commented Mar 13, 2020 at 20:11
Just connect your signal to the clock input and use an async reset:
module see_shorty (
  input      short_signal,
  input      short_signal_clear,
  output reg short_signal_seen
// You can make this negedge short_signal to detect a falling edge
// In the same way you can invert the reset signal
always @(posedge short_signal or posedge short_signal_clear)
   if (short_signal_clear)
      short_signal_seen <= 1'b0;
   else
      short_signal_seen <= 1'b1;
endmodule // see_shorty
Synchronize short_signal_seen to your clock and use the result to make a short_signal_clear pulse which clears the FF again. (I leave those details to you)
Make a reset pulse:
// Make a reset pulse if short signal (synced to system clock) is high
// but previously it was low
reg  delayed_sig;        // Need previous state of signal
wire short_signal_clear;
always @(posedge clk)
   delayed_sig <= short_signal_seen_synced;
assign short_signal_clear = short_signal_seen_synced & ~delayed_sig;
  • \$\begingroup\$ Thank you, that looks good! I would personally use a chain of two FF to synchronize the signal to my clock domain, is that sufficient? :) \$\endgroup\$
    – Katharina
    Commented Mar 13, 2020 at 20:25
    \$\begingroup\$ Yes. That is the norm. Then a third FF with an exor to make the reset pulse. \$\endgroup\$
    – Oldfart
    Commented Mar 14, 2020 at 7:44
  • \$\begingroup\$ Thanks. What do you mean by "exor"? I would have generated the pulse in Verilog by asserting the reset signal, and with the next clock edge, deasserting it, like a small state machine. Is there a simpler way? :) \$\endgroup\$
    – Katharina
    Commented Mar 14, 2020 at 22:35
    \$\begingroup\$ Sorry, probably not an exor gate. I'll update the code \$\endgroup\$
    – Oldfart
    Commented Mar 14, 2020 at 22:44
How bout something like this? The clock is your local clock, common to all the flip flops. R is the reset (usually power on) for the FFs.
The glitch filter is optional.
Answer to OP's Question
S is just the SET input of the flip flop.
  • \$\begingroup\$ What is the "S" input from the first flip flop? Will this catch signals that are shorter than the clock period and do no coincide with the clock edges? \$\endgroup\$
    – Katharina
    Commented Mar 13, 2020 at 19:33
