I have a couple of SGM3005 chips and want to use them as switches in an audio circuit, but they don't support negative signals. The classical solution would be to bias the COM1 input, right? But, what if instead of biasing the input pin, I apply some negative voltage to the GND pin, will it work?
http://www.kean.com.au/oshw/oximeter/SGM3005%20Dual%20Analog%20Switch.pdf
