As discussed earlier, terminal voltages would never exceed the CV value (4.2V for Li-Ion cell) while charging:
If that's the case, the CC value should be the current value at the time the terminal voltages just reached to the CV value.
Could we precisely determine the exact "Constant Current" value (the Current Limit value, actually) of a given Lithium battery by the following procedure:
- Determine the battery chemistry to determine the CV value (eg. Li-Ion battery, 4.2V/cell)
- Use its capacity value (or make a safe assumption) and use 0.5C to start charging.
- At the moment the terminal voltage of the battery is just reached to the CV value (4.2V for Li-Ion), increase current limit of the power supply to the point that the actually drawn current is not increasing anymore.
- The actual current at this moment is the CC value.
- To fine tune this determined CC value, repeat the steps from
#2
for one or two more times.
Is above procedure correct for determining the exact practical CC value of any Lithium (based) battery?
Rationale
In order to safely use any Lithium Ion (or LiFePO4) battery for a custom application (device), charging characteristics should be determined if it is undocumented (like a cell phone battery).
If this is an appropriate procedure, then we could verify a battery follows its datasheet specs.
