Having the hardest time with this TLC59116 LED Driver IC from Texas Instruments. I have done a crazy amount of debugging and still cannot get it to drive a single LED. I have followed all the instructions on the datasheet, as well as referenced every software library/tutorial I could find to make sure I am doing everything properly, but it still will just not drive an LED.
I have double checked the validity of the chip and can confirm it is stable.
Here is how I currently have it hooked up:
And here is my I2C code:
  void writeRegister(char reg, char data) {
    char buffer[2];
    buffer[0] = reg;
    buffer[1] = data;
    i2c->write(address, buffer, 2);
  writeRegister(MODE1, 0b00000000); // defaults
  writeRegister(MODE2, 0b00000000); // defaults
  writeRegister(GRPPWM, 0xFF);
  writeRegister(GRPFREQ, 0xFF);
  writeRegister(LEDOUT0, 0b11111111); // led "fully on"
  writeRegister(LEDOUT1, 0b11111111);
  writeRegister(LEDOUT2, 0b11111111);
  writeRegister(LEDOUT3, 0b11111111);
  writeRegister(PWM0, 0xFF);   // full brightness
  writeRegister(PWM1, 0xFF);
  writeRegister(PWM2, 0xFF);
  writeRegister(PWM3, 0xFF);
  writeRegister(PWM4, 0xFF);
  writeRegister(PWM5, 0xFF);
  writeRegister(PWM6, 0xFF);
  writeRegister(PWM7, 0xFF);
I have tried several enumerations of this code but it makes zero difference.
Like... am I missing something integral here?
    \$\begingroup\$ Are you sure the address is correct? \$\endgroup\$
    – Passerby
    Mar 17, 2020 at 16:38
  • \$\begingroup\$ ya its 0b1100 000 \$\endgroup\$
    – scottc11
    Mar 17, 2020 at 17:00
  • \$\begingroup\$ ahh 🤦‍♂️..... for some reason the mbed I2C library wanted the 8-bit address -> 0b1100 0000 \$\endgroup\$
    – scottc11
    Mar 17, 2020 at 17:03
  • \$\begingroup\$ Happens to us all. Some frameworks want 7 some want 8. \$\endgroup\$
    – Passerby
    Mar 17, 2020 at 19:33
I was using the wrong I2C address. I was using the 7-bit address of 0b1100000 instead of the 8-bit address 0b11000000...
    \$\begingroup\$ Good. Don't forget that you can accept your own answer (maybe after a day or two, I think) to indicate that the problem is solved. \$\endgroup\$
    – Transistor
    Mar 17, 2020 at 17:11
