I would like to make sure I'm reading this value correctly as 22.10 ohm. I think the first color on the left is white, but the second color I am nearly certain is gold. The gold band must be the multiplier then, and I am miss-reading the first color which may actually be silver. Let me know what you think, I'd like a second opinion.
Edit: Is it possible for this resistor to be a 220 ohm 5% with a white reliability band?
Edit1: Additional info.
- I can't physically measure this component, this is an image of an identical board I received from a supplier of the part.
- This is on an oven control board. This resistor burnt up on my board and I would like to replace the part.
