I would like to add this part https://fr.rs-online.com/web/p/guides-de-lumieres-led/8796223/ on my eagle board.
I did the schematic (just to be sure it's in the project) and the "footprint" of the component.
My component has no pads only holes.
The problem is, I don't see it in my board design ...
Any idea to solve this ?
there is my symbol enter image description here there is my device : enter image description here there is my component footprint : enter image description here there is the library : enter image description here
  • \$\begingroup\$ display the appropriate layers. \$\endgroup\$ Mar 19, 2020 at 13:43
  • \$\begingroup\$ So you created the footprint, the symbol, and the device? You need all 3... \$\endgroup\$
    – Ron Beyer
    Mar 19, 2020 at 13:45
  • \$\begingroup\$ @RonBeyer yes I forgot the device, I created it too ! \$\endgroup\$
    – A.Girafe
    Mar 19, 2020 at 13:46
  • \$\begingroup\$ What layers did you put the hole on? Please add a picture of the footprint if you can. \$\endgroup\$
    – Ron Beyer
  • \$\begingroup\$ @MarcusMüller I'm displaying all the layer and there is still nothing :-/ I can see my component on my schematic. \$\endgroup\$
    – A.Girafe
    Mar 19, 2020 at 13:47
I just found something that made it work ! I used the "replace" command to insert the same component and it did the trick. Somehow my library modifications weren't up to date even by using the updating button in the library manager. Thanks for your help guys !
  • \$\begingroup\$ Yes, once you place a device on your schematic it copies everything out of the library into the schematic file regarding that part. If you update the library, you have to manually update the parts in the schematic to match by using the "Replace". Updating in the library doesn't do anything because there is no connection from a library to a schematic/board. \$\endgroup\$
    – Ron Beyer
    Mar 19, 2020 at 19:12
