I'm doing reverse engineering on a hardware of an equipment, this equipment is able to identify the presence of a RF signal from a key fob.
Unfortunately, it was not possible to identify the integrated circuit, it has a mask, a number that makes no sense to me and I was not able to find information about it.
I don't know either the exactly values of the capacitors, I cannot remove them from the circuit. So, I would like to know, based on the incomplete information of the figure below, could someone identify, or make a guess, about which integrated it would be?
Below is the image of the antenna of the circuit. The other circuit components are on the other side of the board
EDITED: Below is the image of the IC, the code printed on it surface:
506
1403
M83
PS: Sorry for the lack of information in the question, any information or guess may be valid.
    \$\begingroup\$ do you have a picture of the IC? Generally, I think without proper IC markings, you'll be out of luck, unless you start reverse-engineering the RF signal yourself: there's a lot of cheap receiver ICs \$\endgroup\$ – Marcus Müller Mar 20 '20 at 14:49
    \$\begingroup\$ Whatever it is, it won't be anything as simple as a "frequency meter." The fob will transmit data on the radio signal. Your IC will receive the signal and decode the data. \$\endgroup\$ – JRE Mar 20 '20 at 14:51
    \$\begingroup\$ You need to post a picture of the IC, and write out the numbers printed on it as best you can decipher them. \$\endgroup\$ – JRE Mar 20 '20 at 14:51
  • 4
    \$\begingroup\$ Also "the number makes no sense to me": well, it might make sense to someone else, that's why you're asking, right? so, what's the number? \$\endgroup\$ – Marcus Müller Mar 20 '20 at 14:53
    \$\begingroup\$ @Daniel sadly, you were a bit right, and that number doesn't strike much of a bell with me, but the picture says "IC without even a manufacturer logo", so chances are this is something extremely low-cost; maybe some old analog IC, which would explain the custom packaging. \$\endgroup\$ – Marcus Müller Mar 20 '20 at 17:35
