I've created a circuit (image below) Using the LTC3623EUUD#TRPBF. The output should be 5v, however the voltage is oscillating up and down. What would be causing the oscillation?
I used solder paste and surface mount components for this.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI've created a circuit (image below) Using the LTC3623EUUD#TRPBF. The output should be 5v, however the voltage is oscillating up and down. What would be causing the oscillation?
