I was recently doing a first-course lab on Induction Motors. We were asked to plot the torque-slip characteristics of a 4-pole 3 phase induction motor (3.7kW).
I just analyzed the data I plotted from the wattmeter readings (connected as shown below) and the rpm measured using a tachometer.
part of ckt diagram showing wattmeter connection: voltage coil across A of IM and 3-ph N, current coil sees current entering A of IM
Here's the T-slip data I plotted on my spreadsheet.
t-slip from my lab
Data points were obtained by gradually loading a mechanically coupled DC generator.
I don't think my plot looks anything like the t-slip diagrams from my lectures and even Google Images.
Can someone who knows what's going on explain it to me?
It looks pretty normal to me; as you increase torque the motor slips a little more. Maybe the graphical representations you have previously seen look different but are reflected in your diagram. For instance, here's one that looks pretty similar: -
Picture from here.
And your graph appears to be coinciding with "the stable region". But, if you looked at this graph that shows torque against speed you might get confused: -
Taken from a stack exchange question.
In this graph the right hand side of the characteristic is where you graph begins because it shows speed and not slip on the x-axis.
| improve this answer | |
  • \$\begingroup\$ Yes, you're right. Thanks! \$\endgroup\$ – William R. Ebenezer Mar 23 at 13:00
    \$\begingroup\$ Also, keep practicing guitar and piano - you never stop practicing! \$\endgroup\$ – Andy aka Mar 23 at 13:02
  • \$\begingroup\$ Ah, yes, I will! \$\endgroup\$ – William R. Ebenezer Mar 23 at 13:03
  • \$\begingroup\$ BTW I just heard some of your tracks. I liked "So you wanna be a soldier" very much. \$\endgroup\$ – William R. Ebenezer Mar 23 at 13:10
  • \$\begingroup\$ Ah, maybe you also like Pink Floyd. I won a competition with that song! \$\endgroup\$ – Andy aka Mar 23 at 13:24
