I commonly see voltage references implemented with op-amp buffers as shown below. That's the simplest way.
However, see below another way of doing it which I found in a meter:
The second one seems it has more robust filtering. Is it really needed? Of course, I don't know why the designer did that. There may be a reason. I'd like to understand under what criteria the designer would choose this topology.
