https://www.circuitlab.com/circuit/gu5zh6pdvj8q/parallel-and-series-question-circuit/
Do these circuit schematics accurately represent these other 2 circuit schematics, which I made using Tinkercad?
If so, is the resistor network for C2 built to match the equation
1/(1/(330 + 330 + 330 + 220) + 1/(330 + 330 + 330 + 100))
Which represents one serial circuit with a combined value of 1110 ohms, and another of a combined value of 1090 ohms, both in parallel, which should give a combined ohm value at the output of the circuit of 570 ohms?
If yes, how come my multimeter reads 500 ohms at the beginning and the end of these resistor networks?
EDIT:
Solved, the 400/500 ohms is because of the tolerance.
  • \$\begingroup\$ You have one long series chain starting at A30 and ending at C29. \$\endgroup\$
    – Majenko
    Commented Mar 24, 2020 at 12:40
  • \$\begingroup\$ @Majenko How come? The resistor at A30 is not connected to the network starting from c29? And ar ethen added in parallel at 13? \$\endgroup\$ Commented Mar 24, 2020 at 12:44
    \$\begingroup\$ A30-|===|-A26-B26-|===|-B22-A22-|===|-A18-B18-|===|-B13-D13-|===|-D17-E17-|===|-E21-D21-|===|-D25-C25-|===|-C29 \$\endgroup\$
    – Majenko
    Commented Mar 24, 2020 at 12:47
    \$\begingroup\$ 560 ohm and 10 ohm are common values so why all the drama? \$\endgroup\$
    Commented Mar 24, 2020 at 12:51
    \$\begingroup\$ Until you have something connecting A30 and C29 (like you have done for the column 13) you won't have anything in parallel. \$\endgroup\$
    – Majenko
    Commented Mar 24, 2020 at 12:57
You yet have to connect Line 29 with Line 30.
Then your curcuit represents your formula.
  • \$\begingroup\$ Thank you for you answer, Could I possibly ask you to draw the schematics for it aswell, so I can understand how the schematics relate to real life better? \$\endgroup\$ Commented Mar 24, 2020 at 12:50
  • 6
    \$\begingroup\$ @GeorgeWTrump, much better if you draw the schematics yourself, then you'll really understand properly. The schematic editor here is a breeze to use. \$\endgroup\$
    – TonyM
  • \$\begingroup\$ @TonyM Well I gave it a go at that, and made my own diagrams. I have added them to the edited question. Perhaps you could take a look at it? \$\endgroup\$ Commented Mar 24, 2020 at 13:31
    \$\begingroup\$ @GeorgeWTrump, thanks for putting the work in. It needs to be visible in your question rather than as a link. Readers need to see it in front of them and links can break anyway. Please can you make that edit. \$\endgroup\$
    – TonyM
    Commented Mar 24, 2020 at 14:08
Resistor value
What is the resistor value 570 ohm for? Does it really matter if it is that precise? If 550 ohm would suffice, just add a 330 and 220 ohm resistor to get 550 ohm.
Note that each resistor has an accuracy so probably with two 5% precision resistors you get away with 550 ohms.
Breadboard
To put this on a breadboard, place one resistor from e.g. a30 to a26, and than on the same vertical line, starting at e.g. b26 to b22 the second resistor. Now you have the resistor in series.
To put two resistor in parallel, place two resistors with both ends on the same vertical lines, e.g. one from a30 to a26 and the second from b30 to b26.
    \$\begingroup\$ Right, Tinkercad wouldn't allow me to change the size of the resistor, but in reality the last 220 and 110 ohm resistors are in parallel, with both sites sharing nodes. Also, it was not only because of me needing a 570 ohm resistor value, I also wanted to challenge myself and learn more about resistor networks. Edit: Oh wait, the last resistors are only connected with one end. I will try to change that. \$\endgroup\$ Commented Mar 24, 2020 at 12:47
    \$\begingroup\$ Also you can create the two series subcircuits on each end (so one below the split line between e an f, and the other above), and than connect the most left ends together and most right ends (to make both series into a parallel configuration). \$\endgroup\$ Commented Mar 24, 2020 at 12:53
    \$\begingroup\$ Well, that would be a possibility, but the schematics I made is not for the whole circuit, only the part with resistors. In real life the other part is filled with a potentiometer and a LED 8x8 matrix. But thanks for the suggestion anyways, it has given me a new tool in the future :) \$\endgroup\$ Commented Mar 24, 2020 at 13:01
    \$\begingroup\$ Yeah, I usually use CircuitMaker for making the circuits in the first place. I just couldn't figure out how to translate the other way around. But I have tried to make some diagrams, perhaps I could ask you to take a look at them? \$\endgroup\$ Commented Mar 24, 2020 at 13:34
    \$\begingroup\$ It seems 400 ohm is strange (I didn't check all color codes of the resistors). However, you should measure each series (disconnect the other), to rule out which string is ok, than check each resistor separately (while breaking the rest of the circuit). \$\endgroup\$ Commented Mar 24, 2020 at 14:20
