I'm having trouble understanding the electric principles that allow a center tapped transformer to work. Lets say we're working with 240/120V. I understand if you connect a voltmeter across the top and bottom wires, you'll get 240V, and 120V between the center tap and other two wires. This is where I'm having trouble. The center tap is essentially a grounded neutral wire if my understanding is correct.
--------------A
--------------G
--------------B
Here is my secondary transformer. So i measure between A and G and get 120V because A is 120V more than G which is 0. So now when i measure between G and B i still get 120V telling me G is 120V more than B, or B is 120V less than G. This is the part that confuses me. How can my center tapped wire G which is grounded be at a higher voltage than B when it is supposed to be 0? Thinking about it the other way still confuses me as well; how can B be at a 120V less than G, what would that mean? Can someone explain the theory behind why/how this works?
  • 4
    \$\begingroup\$ the center tap is not a grounded neutral wire .... G is not 0 V ..... you are dealing with AC, there is no A is 120 V higher than G .... there is only voltage between A and G is 120 V .... reverse the meter leads ... do you get a different reading? \$\endgroup\$
    – jsotola
    Commented Mar 24, 2020 at 16:02
    \$\begingroup\$ In some countries the final mains AC for the consumer houses is made with centertap transformer from 10kV area distribution voltage. There the centertap is the grounded neutral and people get two 120VAC lines to their houses. Voltage between the lines is 240V \$\endgroup\$
    – user136077
    Commented Mar 24, 2020 at 16:03
6 Answers 6
6
With DC it's obvious.
Figure 1. Two 9 V batteries series connected but with various grounding options.
How can B be at a 120V less than G, what would that mean? Can someone explain the theory behind why/how this works?
You are forgetting that your meter only measures magnitude of an AC voltage. There is no sign so saying that B is less than or greater than ground doesn't make much sense.
Figure 2. For AC we have the same situation as with DC but with no sign - just the voltage magnitudes.
When working with AC, therefore, referencing to ground doesn't tell you what the voltage is between two non-grounded points. Let's look at a high-leg delta transformer arrangement which should be familiar to you in North America (but always looks so unbalanced to us Europeans).
Figure 2. This transformer arrangement gives the possibility of obtaining single phases at 120 V, 240 V or 208 V plus the possibility of 3-phase 240 V. Image source: Wikimedia Commons.
If you stick one probe of your meter into the neutral (earth) terminal and measure around the circuit with the other you will get:
L1 - N:   120 V
L2 - N:   120 V
L3 - N:   208 V
These are all correct but without the knowledge of the transformer configuration there is nothing to tell you that these have three different phase angles. If we then take some more readings we get a better picture:
L1 - L2:  240 V
L2 - L3:  240 V
L3 - L1:  240 V
With three points and three same voltage measurements between any two of them the only solution is an equilateral triangle - a three-phase supply. Note again that all the voltages are "positive" as we are only reading magnitude.
Try not to think about the voltage potentials in relation to the vertical direction of your diagram. Also, transformers work on AC, not DC, so the actual voltages are constantly changing with respect to each other in time.
0V is a relative term in AC. In fact, at 60Hz, A and G alternate being 0V 60 times a second. But it's convenient to think of the voltages as a magnitude, like when we put a DMM on said transformer and measure it.
The secondary can have many taps, not just a center tap. And the voltages on those taps can all be relative to a single common tap, or they can be isolated and independent from each other. That's the beauty of a transformer.
For example, in this schematic diagram of a transformer, it has two independent outputs, 30V and 18V, each with its own center tap. This one also has two options for inputs, which allows more flexibility for specific input voltages.
"So now when i measure between G and B i still get 120V telling me G is 120V more than B, or B is 120V less than G."
In the example diagram shows the center tap at 0V for conveniance, so that you can do the math to show the magnitude of the voltage between those two points. Tutorials point has a nice write on this and their image helps too.
As you can see they have placed a ground symbol at the center tap. This is just to help as a reference point. The magnitude from measured on \$Na\$ and \$Nb\$ is still \$V\$ for each tap.
A 'centre-tapped' secondary is actually two identical secondary windings connected in series, as shown.
The dots indicate identical winding ends (current direction being outward at the dotted ends and inward at the opposite ends at the same instant of time or vice versa). With the windings so connected (series-aiding), the total voltage would be 240 V.
With one of the windings being reversed (in series-opposition), the total voltage would be zero.
The outputs are anti-phase. When other phase has maximum, the other phase has minimum. If you were able to measure the phase, the other would be +120VAC and the other one -120VAC, but the polarity/phase is not indicated with minus sign, but with degrees of phase. Same as with two 9V batteries, it's 18V between ends, 9V over one battery and 0V center, and -9V between other battery and 0V center, and you are able to measure polarity because it's DC.
At some instant in time, "A" will be at +120 V relative to the center tap, and "B" will be at -120 Volts relative to the center tap. A half-cycle later, "A" will be -120 V, and "B" will be +120 V.
The voltages on A and B relative to G will be continually changing, but they will always be the same magnitude, but opposite polarity.
Relative to G, at a particular instant in time, A will have a peak voltage of 170V and, also relative to G, B will have a peak voltage of -170V.
Assuming the line frequency is 50Hz then 10ms later A will be at -170V peak and B will be at +170V peak, both voltages being relative to G.
