I want to use a rail-to-rail op-amp as a differential amplifier.
The op-amp is supplied by 3.3V and the input signals swings from 0 to 5V. I want the output to swing between 0 and 2.5V.
My question is if the schematic below safe, in the sense that the inputs of the op-amps will not see voltages higher than VCC+0.3V.
I assume it is as the positive side of the input signal goes through that voltage dividers but I am not sure.
