image of power adapter usedI have installed a nine volt DC power source to take the place of the six 1 1/2 volt series-ed AA batteries, because the trash can lid circuit eats batteries. I installed the power pack after the switch which cuts out the batteries, so in case of a PG&E power outage I can close the switch and run trash can on batteries. I want to know, if I replace the standard AA batteries with rechargeable AA batteries, can I just leave the battery switch closed with no issue of the batteries and power supply being paralleled together?
New contributor
Keith Brumbaugh is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • \$\begingroup\$ perhaps the universe is trying to tell you to stop generating so much garbage ... lol \$\endgroup\$ – jsotola Mar 26 at 3:08
  • \$\begingroup\$ Exactly what is this 'nine volt DC power source'? \$\endgroup\$ – Bruce Abbott Mar 26 at 3:40
  • \$\begingroup\$ Standard 9 VDC 3 amp power adapter plugged into 120 VAC outlet. \$\endgroup\$ – Keith Brumbaugh Mar 26 at 3:58
  • \$\begingroup\$ See image above \$\endgroup\$ – Keith Brumbaugh Mar 26 at 4:41
    \$\begingroup\$ @jsotola or to get a trash can with a manually operated lid - foot pedal type perhaps. Saves the waste batteries as well as the electricity of the power supply 24 & 7... \$\endgroup\$ – Solar Mike Mar 26 at 5:24
Paralleling a power supply and batteries is not recommended without some sort of circuit to make sure they don' keep being charged uncontrollably. First you need to tell us what type of batteries and the exact voltage on your power supply (is it regulated or unregulated). Then you can get a more accurate answer.
However, I will try to help. The simplest thing you can do is place a diode (Shottky preferred) going from the battery pack towards the trash can. Depending on the type of power supply, you will probably need another diode from the supply to the trash can. The first one will prevent uncontrolled charging of batteries, while the second one will prevent the slow discharge of the batteries through the power supply. Then you need a resistor across the first diode to enable a trickle charge (in case you're using NiMH cells, the trickle charge current must be 0.05C or no more than 1/20 of the capacity rating).
The value of the resistor depends on the exact voltage of your power supply, but my rough estimate would be around 47-100 ohms.
Keith Brumbaugh is a new contributor. Be nice, and check out our Code of Conduct.
