-3
I need a solid state relay for switching between DC to dc converter and a amplifier. Clearly, The 24 VDC out from dc to dc converter must be given to amplifier drain voltage, here i am introducing a solid state relay between them so 24V is connected to amplifier based on the micro controller control signal. If control is high then , switch is ON then amplifier is connected to 24V. For this application, i need a solid state relay. can anyone recommend the relay. i have searched for relay but i am unable to find, please help me out of this. The relay's load current must be atleast 1A.
New contributor
Thumati Naga lavanya is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
