I am stuck finding the Thévenin voltage in this circuit.
What I did first is remove the current source and replace it with an open circuit. After that I got the Thévenin resistance which is the equivalent resistance of the circuit. R-equivalent = 10 + 20 + 10 = 40. So now how do I get the Thévenin voltage (Thévenin equivalent)?
  • \$\begingroup\$ You might want to check your first calculation. \$\endgroup\$ Commented Mar 27, 2020 at 17:28
    \$\begingroup\$ It's simply 10 volts in series with 10 ohms by visual inspection and the mildest mental arithmetic. Can you see why? \$\endgroup\$
    Commented Mar 27, 2020 at 17:29
  • \$\begingroup\$ @Andyaka how did you get the 10 ohms ? sorry but i'm really bad at circuits...like really really bad lol. I thought i am supposed to get the equivalent resistance of the 3 resistors! and why is the thevenin equivalent 10 volts \$\endgroup\$
    – AhmadBenos
    Commented Mar 27, 2020 at 17:34
  • \$\begingroup\$ @SpehroPefhany did i get the resistance wrong ? \$\endgroup\$
    – AhmadBenos
    Commented Mar 27, 2020 at 17:36
    \$\begingroup\$ Draw it out. Yes. \$\endgroup\$ Commented Mar 27, 2020 at 17:47
Observe that the circuit can be redrawn as follows:
Calculate the total resistance across the current source. Use Ohms Law to determine the voltage across R1. That same voltage is across the series combination of R2 & R3. Now calculate the voltage across R3.
  • \$\begingroup\$ That's wrong what you have said. You have to measure the resistance from the side of ab. And the thevenin voltage across R3. Not R1. I will include reference from book of Alexander, Sadiku \$\endgroup\$
    – Sadat Rafi
    Commented Mar 28, 2020 at 7:16
-1
There are two processes to find it. The first one is using source transformation. The 2A current source and the 10 ohms resistance in parallel can be replaced by a voltage source of 20 volts and a series resistance of 10 ohms.
So, from this circuit, you will get Thevenin resistace= 10 ohms and Thevenin voltage = 10 volts.
Another method is applying the rule;
Thevenin voltage = Thevenin resistance x Short circuit current of the load terminal
According to this,
The short circuit current is calculated using the current divider law. This will also give Thevenin voltage = 10 volts.
  • \$\begingroup\$ Note the direction of the current source. When doing the source transformation, it should really be -20V or change the polarity of your voltage source. \$\endgroup\$
    – Big6
    Commented Mar 27, 2020 at 18:01
  • \$\begingroup\$ Oh, thanks. Didn't noticed that \$\endgroup\$
    – Sadat Rafi
    Commented Mar 27, 2020 at 18:03
    \$\begingroup\$ Please don't give out answers to homework problems so easily. We expect the OP to do some work and tell us specifically where they are stuck. \$\endgroup\$ Commented Mar 27, 2020 at 18:07
  • \$\begingroup\$ Look closer. I've applied the current divider law. 1 amp flowing through the short-circuited line then through 10 ohms. Another 1 ampere is flowing through the 10 ohms resistance at the left side. No current will flow through the 20 ohms resistor under short circuit condition. \$\endgroup\$
    – Sadat Rafi
    Commented Mar 27, 2020 at 18:35
  • \$\begingroup\$ I've checked again. Please, provide your answer. It would be helpful for finding a mistake if it is made. \$\endgroup\$
    – Sadat Rafi
    Commented Mar 27, 2020 at 18:44
