I have a comprehension question regarding the design of a reverse phase dimmer. I have a picture attached of the part of the circuit I do not understand:
The line is connected to the Drain of Q2 and the load is connected to the Drain of Q3. The sources are connected together and the gates are driven by an IC or MCU. So I understand that the complete sine wave can pass the series transistors. Now what I do not understand is why the GND rail is connected to the source of the AC path between the sources of the MOSFETs. Would that not induce high voltages on the GND rail and destroy the low voltage components like the IC or MCU? Or am I getting this completely wrong... Thank you very much for any kind of answer!
    \$\begingroup\$ Please show more of the schematic to put the parts in some context. Also, describe what a reverse phase dimmer is and how it differs from a "normal" phase control dimmer. \$\endgroup\$
    – AnalogKid
    Commented Mar 27, 2020 at 17:34
GND is a term we can attach to any node on a circuit, usually it's a node with a lot of common connections and we usually refer to other voltages relative to that.
It's not uncommon to have a node called GND that is not at earth potential, it may be floating, or (as in this case) it might be at mains potential.
Suppose we have a Vdd for the MCU used in the above circuit. If the Vdd is +5V relative to GND, it doesn't matter if GND is at 240VAC relative to earth, so long as Vdd-GND is 5V, that's what the MCU sees.
Now if you were to touch one of the MCU pins to earth, then the MCU would be destroyed. Similarly if you were programming the MCU using an in-circuit emulator or programmer connected through a USB interface that is grounded, the MCU would be destroyed and possibly much more.
When working with or developing this kind of circuit it's essential to use devices such as a mains isolation transformer or a USB isolator (or both for those of us who like belt-and-suspenders security).
