I'm working on a project where I'm simply reading the amount of light emitting from an IR led with an IR sensor.
For some reason, after the IR led reaches full luminosity, it takes a minimum, whopping 500ms for the IR sensor's readings to drop from 65536 (16 bit resolution) to ~0.
This is my circuit:
Figure 1. OP's schematic redrawn by @Transistor (for verification).
This is my code:
#include <ADC.h>
ADC* adc;
int ir_led = A8;
int ir_sensor = A9;
void setup() {
    Serial.begin(115200);
    configureADC();
    pinMode(ir_led, OUTPUT);
    pinMode(ir_sensor, INPUT);
    delay(1000);
void loop() {
    digitalWrite(ir_led, HIGH);
    delay(10);  // wait for ir led to reach full luminosity
    int start_time = millis();
    digitalWrite(ir_led, LOW);
    while (adc->analogRead(ir_sensor) > 50); // wait for LED to turn completely off: a reading of 50 out of 65536 is equivalent to 0 with environmental noise
    int end_time = millis();
    Serial.print("DELAY TIME (ms): ");
    Serial.println(end_time - start_time);
void configureADC() {
    adc = new ADC();
    adc->setAveraging(16); // set number of averages
    adc->setResolution(16); // set bits of resolution
    adc->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED_16BITS);
    adc->setSamplingSpeed(ADC_SAMPLING_SPEED::MED_SPEED);
    adc->setAveraging(16, ADC_1); // set number of averages
    adc->setResolution(16, ADC_1); // set bits of resolution
    adc->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED_16BITS, ADC_1); // change the conversion speed
    adc->setSamplingSpeed(ADC_SAMPLING_SPEED::MED_SPEED, ADC_1); // change the sampling speed
Serial output:
Plotting the sensors readings:
Some delay is expected, but 500ms does not make sense. Can someone help me figure out where this delay is coming from and why?
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Jun 8, 2020 at 2:37
Your problem is for your Opamp. As I see, your RC value is 100nF and 1MOhms is 0.1 seconds, and your plot is a nice 1/0.1s+1 plot. So everything is OK based on your circuit. if you want to increase speed, lower C or R to get a better speed. Your 500 ms delay is a 5 time of time constant of this circuit, which is also shows me that it's a first order transfer function. your exact equation in time based system is 1 - e^(-t/RC) where R and C is your capacitor and resistor in your Opamp.
  • \$\begingroup\$ Since I obviously would want to fastest possible response time, is there a minimum or optimal capacitor and resistor value that I should choose? \$\endgroup\$
    – Ietpt123
    Mar 29, 2020 at 0:05
  • \$\begingroup\$ @letpt123 In that case, remove capacitor, or simply reduce Resistor to 1K for .1ms response time as a low value for this. \$\endgroup\$ Mar 29, 2020 at 0:20
  • \$\begingroup\$ Is there any incentive for me to keep the capacitor? Why not go lower to 1 ohm or just remove the resistor as well for the fastest theoretical response time? \$\endgroup\$
    – Ietpt123
    Mar 29, 2020 at 0:23
  • \$\begingroup\$ Your diode needs to be biased, so you need resistor and must use of a rather big one, so you can only play with capacitor, to make the circuit without delay, you can remove C but can't reduce R lower than 10K i think, where current through sensor is increased and cause sensor burning \$\endgroup\$ Mar 29, 2020 at 0:31
  • \$\begingroup\$ Okay good to know, Thank you for your help \$\endgroup\$
    – Ietpt123
    Mar 29, 2020 at 0:40
