I'm tring to build a led display with 32 strips of ws2812b led strips with 60 leds each. That's a total amount of 1920 leds. How many power supplies should I buy? Given the max current of 50mA per leds, that's a 50mA x 60 x 32 = 96A. I'm going to buy to power supplies of 5V 60A (https://www.amazon.it/HAILI-Trasformatore-Adattatore-Alimentazione-Telecamere/dp/B07Y38SMQ3/). What should be the connection of the strips? Should I power every side of each strip? I made a schema:
Do you have any suggestions to connect all these cables with each other? (32 + 32 each side).
The Led strip I'm using is the 1m 60 IP30 + WS2812BECO Black PCB as pictured here:
