I've created a ground plane on my Proteus schematic but for some reason the autorouter is totally ignoring it and trying to link all of the ground connections with traces.
How do I fix this and force the autorouter to use the ground plane?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI've created a ground plane on my Proteus schematic but for some reason the autorouter is totally ignoring it and trying to link all of the ground connections with traces.
Then you won't face this problem. If you want, you may comment your email then I can send you the video of the process.
Look the connection is mixed with the ground plane. It won't be visible if you print bottom copper.
