I have designed a register bank (pipeline register) to be used in a pipeline-architecture. The code of the register is:
module if_id(   input clk,
                input [31:0] newPC,
                input [31:0] instr,
                output reg [31:0] newPCout,
                output reg [31:0] instrOut);
    reg [63:0] temp;
    always @ (posedge clk) begin
        temp <= {newPC,instr};
    end
    always @ (negedge clk) begin
        newPCout <=  temp[63:32];
        instrOut <= temp[31:0];
    end
endmodule
GTKwave Graphs for inputs and outputs of the given module
Now in this waveform, instrOut changes every 2nd clock cycle. Why? I cannot seem to find the fault in the code, according to me the output should change at every negedge of the clock.
This is the image of the test bench, pipe1 is the instance of if_id module.
module tb(); // tb for fetch
    //fetch
    reg [31:0] baddress;
    reg clk;
    reg pcsource;
    //fetch
    wire [31:0]newpc;
    wire [31:0]instr;
    //if_id
    wire [31:0]newpcpipe1;
    wire [31:0]instrpipe1;
    //decode
    wire [31:0]rd1,rd2;
    wire [31:0]imm;
    wire [4:0]rs,rt,rd;
    wire [5:0]opcode;
    //main Control
    wire [3:0]ex;
    wire [2:0]mem;
    wire [1:0]wb;
    //id_ex
    wire [3:0] exo;
    wire [1:0]wbo;
    wire [2:0]memo;
    wire [31:0] rd1o;
    wire [31:0] rd2o;
    wire [31:0] immo;
    wire [4:0]  rso;
    wire [4:0]  rto;
    wire [4:0]  rdo;
    wire [31:0] newPCo;
    //ex
    wire [31:0]tPc;
    wire[31:0] AluRes;
    wire [4:0] regDstAdd;
    wire zero;
    //ex_mem
    wire [1:0]wb_m;
    wire [2:0]mem_m;
    wire zero_m;
    wire [31:0] AluOut_m;
    wire [4:0] regdst_m;
    wire [31:0] newPC_m;
    //mem
    wire PCSrc;
    wire [31:0] aluouto;
    //mem_wb
    wire regWrite;
    wire [31:0] AluOut_w;
    wire [4:0] regdst_w;
    fetch fetch1(clk,pcsource,baddress,newpc,instr);
    if_id pipe1(clk,newpc,instr,newpcpipe1,instrpipe1);
    decode decode1(clk,instrpipe1,AluOut_w,regdst_w,regWrite,rd1,rd2,imm,rs,rt,rd,opcode);
    MainControl mc1(opcode,ex,mem,wb);
    id_ex pipe2(clk,wb,mem,ex,newpcpipe1,rd1,rd2,imm,rs,rt,rd,exo,wbo,memo,rd1o,rd2o,immo,rso,rto,rdo,newPCo );
    ex ex1(newPCo,rd1o,rd2o,immo,rto,rdo,exo,tPc,AluRes,regDstAdd,zero);
    ex_mem pipe3(clk,wbo,memo,tPc,AluRes,zero,regDstAdd,wb_m,mem_m,zero_m,AluOut_m,regdst_m,newPC_m);
    mem mem1(mem_m,AluOut_m,zero_m,PCSrc,aluouto);
    mem_wb pipe4(clk,wb_m,AluOut_m,regdst_m,regWrite,AluOut_w,regdst_w);
    initial begin
        $dumpfile("fetch.vcd");
        $dumpvars(0,tb);
    end
    initial begin
        clk = 1'b0;
        forever #5 clk = ~clk;
    end
    initial begin
        //$monitor($time," clk = %b \n ,instr=%b, newPC = %b,",clk,instrpipe1,newpcpipe1);
        #10 baddress = 32'b0; pcsource = 0;
        #200 $finish;
    end
endmodule
    \$\begingroup\$ It's obvious that temp is only changing on every other clock, which is weird. Show us the code for your testbench. \$\endgroup\$
    – Dave Tweed
    Commented Mar 30, 2020 at 10:28
  • \$\begingroup\$ Test Bench This is the image of the test bench, pipe1 is the instance of if_id module. \$\endgroup\$ Commented Mar 31, 2020 at 4:27
    \$\begingroup\$ Not as an image! Paste the actual code into your question. \$\endgroup\$
    – Dave Tweed
    Commented Mar 31, 2020 at 11:14
Looking at the waveform your instr is weird/wrong.
It is picked-up in tmp at the same clock edge that it changes. This is indicative that instr change at or before the clock edge. Not after.
Did you use this in your test-bench/code?
   instr = some_test_value;
instead of?
   instr <= some_test_value;
