I found that inVerilog, the array can only be declared in reg. And I found that it seems like if can only work in for loop such as
integer i;
reg [3:0] a [0:3];
for (i=0; i<5; i=i+1)
a[i] <= i;
what if I want to run in case?
module testrun(
input [7:0] b,
input clk, rst,
output reg [7:0] c , d, f
reg state = 0;
reg [7:0] a = 5;
reg [7:0] e [0:128];
integer i = 0;
//reg [7:0] command = 0;
always @(posedge clk, posedge rst)
begin
    if (rst)
    begin
        c<=0;
        d<=0;
    end
else begin
    if (state == 0)
    begin
        case (i)
        i: begin
                e[i] <= a + 1;
                f <= a + 1;
                c <= e[i];
                i <= i + 1;
                a <= a + 1;
                state <= 1;
            end
        endcase
    end
    if (state == 1)
    begin
        d <= b + b;
        state <= 0;
    end
end
end
endmodule
above is the code I test to see if the value of a + 1 can write into e[i], then write it into output c in the next clock. However, what I get is the output c is zero all the way. but it shows the expected result of output d. Means case actually working just that array is not working. What is the problem? Or this can only be sone in SystemVerilog? By the way, I use University Program VWF to monitor the result.
Then write it into output c in the next clock.
No you don't.
e[i] does not receive that value until the next clock cycle. Thus c <= e[i]; gets the old value of e[..]. But by the next clock cycle you have changed i, you incremented it: i <= i + 1; so c still does not get that value of e[i]
