How do I determine the width and length from the following cmos inverter layout, given that lambda=0.25um? The answer is Wn=1.0um, Ln=0.25um, Wp=0.5um, and Lp=0.25um. I know that the length is equal to 2 x lambda, but I do not understand how to get width from the layout.
Assume the metal-poly contacts are also 2lambda.
Then the left width is 1+2+2+2+1 = 8 lambda, or 1 micron.
By the way, most inverters, because Pmobility ~~ 1/2 of Nmobility, will have the Pwidth about 2X the Nwidth.
  • \$\begingroup\$ Thank you so much! \$\endgroup\$
    – Alicia
    Commented Apr 2, 2020 at 17:33
