9
Why does DC/DC converters with external mosfet have current limit?
From my understanding, for components with an integrated MOSFET, the limit comes from the components (less performance, the Rdson is often higher), if a too high current flows through the component it risks to heat too much and exceed the junction temperature.
But if I use a DC / DC "controller" which controls an external MOSFET, no current flows through the component itself. It would then be enough to choose a mosfet with a high current Id
I take as an example the TLE6389, the typical application is given in the datasheet
My hypotheses: Does the current limitation come from the current measurement function (the internal logic works up to a current value) or does the limit come from the ability to control a more powerful mosfet (the GDRV pin which controls the gate of the mosfet provides an output between 6 and 8 V)?
    \$\begingroup\$ I rephrased your title since it was misleading \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 13:45
  • \$\begingroup\$ Re-phrasing the question might be seen as a dangerous thing to do given that you have provided an answer and are disagreeing with the other two answers AND it might seem that you are trying to make the question seem more applicable to your answer @DKNguyen. Just saying! \$\endgroup\$
    Apr 2, 2020 at 13:52
  • \$\begingroup\$ OP already responded to my answer, however. \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 13:54
    \$\begingroup\$ I hope you aren't using the fact that you got a response from the OP as a good reason for amending his question. Be very, very careful here. \$\endgroup\$
    Apr 2, 2020 at 13:55
  • \$\begingroup\$ He seems to be directly responding to the way the question has been interpreted. \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 13:57
7 Answers 7
The reason behind the current limit may be a business reason, rather than an engineering reason.
The design may have been commissioned by a specific customer to a specific brief (accompanied by a large and lucrative order) - probably in the automotive industry judging by the product validation specification. The parameters in the brief then became an essential part of the product specification. Given that Infineon is a German company, the original customer is likely to have been a German automotive manufacturer. Beyond that, your guess is as good as mine.
In the same way, the first microprocessor Intel ever made, arose from a commission by a customer company, for the desk calculator market.
How the company implements that brief is less important to the customer : in this case, the use of an external Isense resistor was presumably acceptable, and at least in theory, allows any other customer to meet other current limit specifications by changing the sense resistor. The internal logic merely senses the voltage across that resistor : it has no way of knowing what the value of that resistor is.
@DKNguyen is correct that the device has gate drive limitations - both in limited current, and fairly slow rise/fall times - and these are adequate for the original brief with the original recommended MOSFET. It is good that these are clearly stated in the datasheet, but that datasheet is primarily written to hand hold the customer in implementing the original brief.
Using the device for other purposes (e.g. a 10A supply) will likely be possible as long as you design around all the other stated limitations (e.g. choose a FET with acceptable gate capacitance, and a suitable inductor).
But I would not expect Infineon to endorse or support such a design - YOU ARE ON YOUR OWN especially if your design is safety critical - unless you get a specific waiver from Infineon after reviewing your design with one of their FAEs. (Contacting them would be a good idea for any serious use of the product ... they may at least confirm (or correct) this hypothesis. But I doubt they'll rewiew your design for less than a hundred thousand units.) This may or may not not matter for your purposes but should be kept in mind if using it outside the datasheet brief.
The stated limit of 2.3A is not a limit of what the controller can withstand, it is a limit that is enforced by the controller to protect the rest of the circuit. The 2.3A value is based on the reference circuit.
You can change this limit. See section 7.10.2 in the data sheet. It says, "The peak current which the buck converter is able to provide is determined by the peak current limit threshold voltage VLIM and the sense resistor RSENSE." It then gives formula to calculate a new RSENSE for a new limit value.
If you want to find the expected peak current for a given design, you might want to simulate the circuit. Or use a handy calculator like the buck calculator at http://schmidt-walter-schaltnetzteile.de/smps_e/smps_e.html If you find you need a higher current limit based on the sim then adjust RSENSE.
  • \$\begingroup\$ so what is the real meaning of the 2.3A limit ? why this value is given in the datasheet (I think this kind of questions shall be asked to the manufacturer) if i can redo a design for providing more current. (Sorry for my english) \$\endgroup\$
    – Juba
    Apr 2, 2020 at 14:19
  • \$\begingroup\$ This seems to me the most logical answer - but the numbers don't fit. The reference circuit with 47mR allows for up to 1.9A peak input current (at 140°C) - but the datasheet claims 2.3A output current. \$\endgroup\$
    – asdfex
    Apr 2, 2020 at 16:36
  • \$\begingroup\$ @asdfex : for a buck converter, Iout > Iin. \$\endgroup\$
    – user16324
    Apr 2, 2020 at 17:44
    \$\begingroup\$ @BrianDrummond Sure Iout can be higher than peak Iin. But there is no such fixed relationship between the two (47mR --> 2.3A), at least not without stating the input and output voltages. \$\endgroup\$
    – asdfex
    Apr 2, 2020 at 18:02
  • \$\begingroup\$ From 7.10.2 in the datasheet (go look), (IPEAK=ILOAD+0.5ΔI) and RSENSE = VLIM/(2 · IPEAK). Recognize that the ΔI will depend on the inductor, switch freq, Vin, Vout, Iout, etc. Work these out to get the 2.3A threshold on current protection. \$\endgroup\$
    – scorpdaddy
    Apr 2, 2020 at 19:52
Gate drive current capability of a controller IC is not unlimited so you cannot just toss an infinitely big MOSFET onto the output. There may be other limiting factors but this is the only one I know of.
EDIT: It's been pointed out that specifying a current instead of a gate charge limit would be a roundabout way of doing things since "there is no reliable way to correlate gate charge to current capacity".
It is true that there is no reliable correlation. So where did 2.3A current rating on the front page then? Sure, there is no reliable correlation for engineering purposes, but you can ball park things based on existing technology, if your objective is marketing purposes.
Consider that similar current ratings are given for MOSFETs on the front-page, but you can't actually achieve them in practice (at least I never can), while \$R_{dson}\$, the useful parameter is buried deeper in the datasheet.
Instead of a gate charge limit (which would require knowledge of too many unknowns about the operating conditions of the end user MOSFET) , these DC-DC controllers tend to bury a gate drive current, not a gate charge limit deeper in the datasheet.
  • \$\begingroup\$ thanks for your answer, so even if the manufacturer indicates 2.3A as limit, if I find a mosfet which can make pass more current and which can be controlled by this controller I can draw more current? \$\endgroup\$
    – Juba
    Apr 2, 2020 at 13:21
  • \$\begingroup\$ @Juba Do you know what MOSFET switching losses are? RDson is not the only thing that fries MOSFETs. If you can find a MOSFET with both lower RDSon and gate charge, I do not see why not but there may be more to the story. \$\endgroup\$
    – DKNguyen
    \$\begingroup\$ This is not the correct answer. If there was a gate charging limit it would specify a gate charging limit. It would not spec a current limit as a round-about way to limit gate charging. There is no reliable way to correlate gate charge to current capacity. \$\endgroup\$
    – scorpdaddy
    Apr 2, 2020 at 13:59
  • \$\begingroup\$ @scorpdaddy Indeed there isn't, but you can somewhat ballpark it, at least marketing purposes on the first page of the datasheet based on available technology. Consider that similar current ratings are given for MOSFETs on the front-page, but you can't actually achieve them in practice (at least I never can), while Rdson, the useful parameter is buried deeper in the datasheet. \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 17:41
  • \$\begingroup\$ Furthermore, DC-DC controllers do not provide a gate charge limit because that would require knowledge of too many unknowns about the operating conditions of the end user MOSFET (operating voltage, switching frequency, etc) deeper in the datasheet. Instead, what is offered is the gate drive current, which is found buried deeper in the datasheet. \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 17:42
Devices that control external MOSFETs can have a wide range of applications, each with it's own output voltage and current requirements.
There may be a requirement that if the load short circuits, the output current may not exceed some stated maximum which can protect the PCB itself (from excessive current damaging the power path), the MOSFET (which will have some maximum allowable current) and the inductor (to protect it from excessive \$I^2R\$ copper losses.
We can set current limits externally on some parts that have an internal current limit (which is usually for thermal protection although not always).
Setting a current limit that is no higher than the requirement of the particular application also permits the use of smaller inductors than might otherwise be necessary (because the limit will prevent saturation).
The maximum current limit in your application is necessary as the body diode of the MOSFET will still conduct even if the MOSFET is turned off.
    \$\begingroup\$ OP is asking about PHYSICAL hard limits, not limiting safety mechanisms \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 13:43
why DC/DC converters with external mosfet have current limit ?
It's sensible when designing any type of power converter to restrict current to prevent overload conditions creating a possible fire risk.
Many decent regulators will monitor their own junction temperature and shut down - current limiting is used for over-current scenarios when the temperature of components are not necessarily that warm but, the circuit could be dumping power into a load that creates a fire risk.
There are fusing limits that need to be prevented. There are also limits to the current applied when using inductors (such as \$L_1\$ in your picture). You don't want it to magnetically saturate.
So, the chip in question allows for using an \$R_{SENSE}\$ resistor and this needn't be used of course but, not using it is not usually a good idea.
    – DKNguyen
  • \$\begingroup\$ That's not how I read the question. \$\endgroup\$
  • \$\begingroup\$ I do not see how you could read it any other way unless you just read the title. OP was quite explicit in the body. \$\endgroup\$
    – DKNguyen
    Apr 2, 2020 at 13:46
  • \$\begingroup\$ I read it MY WAY. \$\endgroup\$
    Apr 2, 2020 at 13:53
    \$\begingroup\$ "So, the chip in question allows for using an RSENSE resistor and this needn't be used of course but, not using it is not usually a good idea." This particular controller is a peak current mode controller, so you need Rsense for the control scheme as well as protection, you can't leave it out. \$\endgroup\$
    – John D
    Apr 2, 2020 at 14:55
First, current limit is a built-in protection for your external FET in case the FET experience dangerous level of current during some rare transient event. For example, if your FET is rated 20A and your normal operational current through the sense resistor is 10A, looks like you can use the 20A FET. But who will protect you if the sense resistor current suddenly go up to 30A under some transient conditions or fault condition? There is no fuse in a DC/DC converter board to protect you.
Secondly, voltage across sense resistor is amplified by a fixed gain amplifier internally. If the voltage is very large, it could saturate the internal amplifier. Sure you can always choose a smaller resistor to allow less voltage drop across the sense resistor, but also current limit has an accuracy requirement. The manufacture don't want to risk going out of spec by not specifying what kinds of sense resistor and current limit you can apply.
Third, the maximum load a DC/DC controller can handle is closely related to the stability requirement of the controller. The controller become less stable(perform less well for a step load change or supply change) when load current is very high. That being said, you can predict the maximum current going through the sense resistor by using your worst case vin/vout ratio. What is your reason for having current higher than the current limit? If that is because that your load go up, then I would say a FET change is not enough since the controller may have stability issue at higher than specification load.
Actually I know this device pretty well and would like to help you: Autmotive application does not oppose a limit on how and where you can use this device, it just determines the way it is qualified and reliability is checked (have a look at AEC-Q100).
The first obvious reason for why the controller can't handle arbitary load currents has already been mentioned. It is the gate driver's limited current/voltage driving capability that will prevent you from using MOSFETs with lower RDSON because these will come with higher gate charge...
The second reason has not been mentioned so far but it is a very important one. This controller uses the so called "peak current mode" control scheme. It is the main reason why there is a sense resistor which is feeding back the switch current into the controller. You can read up on the principles of "peak current mode control" in some appnotes or in Erickson's "Fundamentals of Power Electronics". The benefit of this method is that you end up with a first order control to output transfer function which is easier to compensate. Secondly you need the current measurement anyhow in case you want to protect your device and switch against short circuit conditions. This control method will however restrict the possible inductor values you can choose vs. the sense resistor and the set output voltage. There is a artifical compensation slope inside the controller (it is also depicted in the datasheet) that needs to be "matched" to the current slopes of your measured switch / inductor current.
In section 7.10.1 you can see this restriction on the chooseable inductor. When you do the math for your desired operating conditions you will see that when you choose the inductor according to the given formula, your ripple will run out of "headroom" to the upper current limit.
