I have more than one third party model that I'm trying to import to the simulator in Eagle, which I believe is basically LTspice. I think the models I'm importing are PSpice. At least one is missing the .subckt and .ends syntax, and others have the proper syntax but I get errors that certain lines cannot be simulated or the model has a different number of pins from the part I'm assigning it to. Any help is much appreciated.
Improper syntax:
.MODEL NST45010 pnp
+IS=6.40452e-13 BF=10000 NF=1.27689 VAF=1000
+IKF=0.0486984 ISE=3.50933e-14 NE=1.48639 BR=0.313958
+NR=1.5 VAR=455.615 IKR=0.486984 ISC=1e-16
+NC=3.99246 RB=0.1 IRB=0.1 RBM=0.1
+RE=0.375422 RC=3.90338 XTB=0.1 XTI=1
+EG=1.206 CJE=1.14119e-11 VJE=0.643535 MJE=0.236664
+TF=6.0309e-10 XTF=1000 VTF=582.623 ITF=12.2508
+CJC=9.13615e-12 VJC=0.4 MJC=0.389243 XCJC=0.800175
+FC=0.8 CJS=0 VJS=0.75 MJS=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
Improper syntax:
.MODEL NST45011 npn
+IS=2.13318e-12 BF=246.858 NF=1.25171 VAF=13.7501
+IKF=0.452519 ISE=3.43407e-10 NE=4 BR=24.6858
+NR=1.5 VAR=52.6697 IKR=4.52519 ISC=3.43407e-10
+NC=1.92734 RB=2 IRB=0.1 RBM=2
+RE=0.954359 RC=4.77179 XTB=5.22795 XTI=1
+EG=1.05 CJE=7.56956e-12 VJE=0.469867 MJE=0.31769
+TF=5.84833e-10 XTF=13.8699 VTF=48.1091 ITF=0.193693
+CJC=4.02125e-12 VJC=0.95 MJC=0.340626 XCJC=0.748803
Certain lines cannot be simulated:
* Model Usage Notes:
* 1. The following parameters are modeled:
*       OPEN-LOOP GAIN AND PHASE VS. FREQUENCY  WITH RL, CL EFFECTS (Aol)
*       UNITY GAIN BANDWIDTH (GBW)
*       INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR)
*       POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR)
*       DIFFERENTIAL INPUT IMPEDANCE (Zid)
*       COMMON-MODE INPUT IMPEDANCE (Zic)
*       OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo)
*       OUTPUT CURRENT THROUGH THE SUPPLY (Iout)
*       INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en)
*       INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in)
*       OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo)
*       SHORT-CIRCUIT OUTPUT CURRENT (Isc)
*       QUIESCENT CURRENT (Iq)
*       SETTLING TIME VS. CAPACITIVE LOAD (ts)
*       SLEW RATE (SR)
*       SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD
*       LARGE SIGNAL RESPONSE
*       OVERLOAD RECOVERY TIME (tor)
*       INPUT BIAS CURRENT (Ib)
*       INPUT OFFSET CURRENT (Ios)
*       INPUT OFFSET VOLTAGE (Vos)
*       INPUT OFFSET VOLTAGE VS. TEMPERATURE (Vos Drift)
*       INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
*       INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm)
*       INPUT/OUTPUT ESD CELLS (ESDin, ESDout)
.subckt OPA1678 IN+ IN- VCC VEE OUT
* MODEL DEFINITIONS:
.model BB_SW VSWITCH(Ron=50 Roff=1e12 Von=700e-3 Voff=0)
.model ESD_SW VSWITCH(Ron=50 Roff=1e12 Von=500e-3 Voff=100e-3)
.model OL_SW VSWITCH(Ron=1e-3 Roff=1e12 Von=900e-3 Voff=800e-3)
.model OR_SW VSWITCH(Ron=10e-3 Roff=1e12 Von=10e-3 Voff=0)
.model R_NOISELESS RES(T_ABS=-273.15)
XV_OS N032 N044 VOS_DRIFT_OPA1678
R1 N036 N033 R_NOISELESS 1e-3
R2 N053 ESDn R_NOISELESS 1e-3
R3 N071 0 R_NOISELESS 1e12
C1 N071 0 1
R4 VCC_B N070 R_NOISELESS 1e-3
C2 N070 0 1e-15
C3 N072 0 1e-15
R5 N072 VEE_B R_NOISELESS 1e-3
G1 N036 N037 N005 N004 1e-3
R6 MID N049 R_NOISELESS 1e12
VCM_MIN N052 VEE_B 0.5
R7 N052 MID R_NOISELESS 1e12
VCM_MAX N049 VCC_B -2
XVCM_CLAMP N037 MID N045 MID N049 N052 VCCS_EXT_LIM_OPA1678
R8 N045 MID R_NOISELESS 1
C4 N046 MID 1e-15
R9 N045 N046 R_NOISELESS 1e-3
V4 N068 OUT 0
R10 MID N054 R_NOISELESS 1e12
R11 MID N055 R_NOISELESS 1e12
XIQp VIMON MID VCC MID VCCS_LIM_IQ_OPA1678
XIQn MID VIMON MID VEE VCCS_LIM_IQ_OPA1678
R12 VCC_B N009 R_NOISELESS 1e3
R13 N022 VEE_B R_NOISELESS 1e3
XCLAWp VIMON MID N009 VCC_B VCCS_LIM_CLAWp_OPA1678
XCLAWn MID VIMON VEE_B N022 VCCS_LIM_CLAWn_OPA1678
R14 VEE_CLP MID R_NOISELESS 1e3
R15 MID VCC_CLP R_NOISELESS 1e3
R16 N010 N009 R_NOISELESS 1e-3
R17 N023 N022 R_NOISELESS 1e-3
C5 MID N010 1e-15
C6 N023 MID 1e-15
R18 VOUT_S N055 R_NOISELESS 100
C7 VOUT_S MID 1e-12
G2 MID VCC_CLP N010 MID 1e-3
G3 MID VEE_CLP N023 MID 1e-3
XCL_AMP N007 N034 VIMON MID N013 N020 CLAMP_AMP_LO_OPA1678
V_ISCp N007 MID 50
V_ISCn N034 MID -37
XOL_SENSE_OPA1678 MID N042 N041 N051 OL_SENSE_OPA1678
R19 N034 MID R_NOISELESS 1e12
R20 N020 MID R_NOISELESS 1
C8 N021 MID 1e-15
R21 MID N013 R_NOISELESS 1
R22 MID N007 R_NOISELESS 1e12
C9 MID N014 1e-15
XCLAW_AMP VCC_CLP VEE_CLP VOUT_S MID N011 N018 CLAMP_AMP_LO_OPA1678
R23 VEE_CLP MID R_NOISELESS 1e12
R24 N018 MID R_NOISELESS 1
C10 N019 MID 1e-15
R25 MID N011 R_NOISELESS 1
R26 MID VCC_CLP R_NOISELESS 1e12
C11 MID N012 1e-15
XCL_SRC N014 N021 CL_CLAMP MID VCCS_LIM_4_OPA1678
XCLAW_SRC N012 N019 CLAW_CLAMP MID VCCS_LIM_3_OPA1678
R27 N011 N012 R_NOISELESS 1e-3
R28 N019 N018 R_NOISELESS 1e-3
R29 N013 N014 R_NOISELESS 1e-3
R30 N021 N020 R_NOISELESS 1e-3
R31 N042 MID R_NOISELESS 1
R32 N042 SW_OL R_NOISELESS 100
C12 SW_OL MID 1e-9
R33 VIMON N054 R_NOISELESS 100
C13 VIMON MID 1e-12
C_DIFF ESDp ESDn 6e-12
C_CMn ESDn MID 2e-12
C_CMp MID ESDp 2e-12
I_Q VCC VEE 2e-3
I_B N032 MID 10e-12
I_OS ESDn MID 1e-15
R34 IN+ ESDp R_NOISELESS 250
R35 IN- ESDn R_NOISELESS 250
R36 N024 MID R_NOISELESS 1
R37 N035 MID R_NOISELESS 1e12
R38 MID N016 R_NOISELESS 1
R39 MID N008 R_NOISELESS 1e12
XGR_AMP N008 N035 N015 MID N016 N024 CLAMP_AMP_HI_OPA1678
XGR_SRC N017 N025 CLAMP MID VCCS_LIM_GR_OPA1678
C17 MID N017 1e-15
C18 N025 MID 1e-15
V_GRn N035 MID -113
V_GRp N008 MID 113
R40 N016 N017 R_NOISELESS 1e-3
R41 N025 N024 R_NOISELESS 1e-3
R42 VSENSE N015 R_NOISELESS 1e-3
C19 MID N015 1e-15
R43 MID VSENSE R_NOISELESS 1e3
G5 N032 N033 N002 MID 1e-3
G8 MID CLAW_CLAMP N066 MID 1e-3
R45 MID CLAW_CLAMP R_NOISELESS 1e3
R47 N058 VCLP R_NOISELESS 100
C24 MID VCLP 1e-12
E4 N058 MID CL_CLAMP MID 1
E5 N055 MID OUT MID 1
H1 N054 MID V4 1e3
S1 N057 N056 SW_OL MID OL_SW
R52 MID ESDp R_NOISELESS 1e12
R53 ESDn MID R_NOISELESS 1e12
R58 N033 N032 R_NOISELESS 1e3
R59 N070 N071 R_NOISELESS 1e6
R60 N071 N072 R_NOISELESS 1e6
R67 N037 N036 R_NOISELESS 1e3
G15 MID VSENSE CLAMP MID 1e-3
V_ORp N031 VCLP 8.8
V_ORn N026 VCLP -8.8
V11 N028 N027 0
V12 N029 N030 0
H3 N040 MID V12 10
S6 VCC OUT OUT VCC ESD_SW
S7 OUT VEE VEE OUT ESD_SW
E1 N063 0 N071 0 1
S8 N029 CLAMP CLAMP N029 OR_SW
S9 CLAMP N028 N028 CLAMP OR_SW
Xi_nn ESDn MID FEMT_OPA1678
Xi_np N044 MID FEMT_OPA1678
XVCCS_LIMIT_1 N046 N053 MID N047 VCCS_LIM_1_OPA1678
XVCCS_LIMIT_2 N047 MID MID CLAMP VCCS_LIM_2_OPA1678
R44 N047 MID R_NOISELESS 1e6
R68 CLAMP MID R_NOISELESS 1e6
G7 MID N066 N065 MID 1e-6
R69 N066 MID R_NOISELESS 1e6
H2 N050 MID V11 -10
Xe_n N044 N043 VNSE_OPA1678
R51 N043 ESDp R_NOISELESS 1e-3
R71 N041 N040 R_NOISELESS 100
R72 N051 N050 R_NOISELESS 100
C27 N041 MID 1e-12
C28 N051 MID 1e-12
XVCCS_LIM_ZO_OPA1678 N062 MID MID N067 VCCS_LIM_ZO_OPA1678
Rdc3 N038 MID R_NOISELESS 1
R92 N038 N039 R_NOISELESS 1e4
R93 N039 MID R_NOISELESS 4.286e3
G24 MID N048 N039 MID 3.3333
C33 N039 N038 8.842e-13
R94 N048 MID R_NOISELESS 1
G25 MID N038 VSENSE MID 1
C36 CLAMP MID 1.806e-8
G4 MID CL_CLAMP CLAW_CLAMP MID 1e-3
R62 MID CL_CLAMP R_NOISELESS 1e3
R46 N002 MID R_NOISELESS 2e3
R48 N002 N001 R_NOISELESS 1e8
G9 MID N001 ESDp MID 20e-3
Rsrc2 N001 MID R_NOISELESS 1
C16 N002 N001 6.366e-12
C21 N004 N003 3.98e-10
R49 N004 MID R_NOISELESS 22.86
R50 N004 N003 R_NOISELESS 1e8
G10 MID N003 VEE_B MID 0.4375
Rsrc4 N003 MID R_NOISELESS 1
C14 N005 N006 3.98e-10
R54 N005 MID R_NOISELESS 22.86
R55 N005 N006 R_NOISELESS 1e8
G6 MID N006 VCC_B MID 0.4375
Rsrc1 N006 MID R_NOISELESS 1
Rx N068 N067 R_NOISELESS 1.45e5
Rdummy N068 MID R_NOISELESS 1.45e4
G11 MID N056 CL_CLAMP N068 88.5
Rdc1 N056 MID R_NOISELESS 1
R56 N056 N057 R_NOISELESS 1e8
R57 N057 MID R_NOISELESS 2.83e6
G12 MID N059 N057 MID 36.39
C15 N057 N056 2.14e-10
R61 N059 MID R_NOISELESS 1
R63 N059 N060 R_NOISELESS 9e8
R64 N060 N069 R_NOISELESS 1e8
C23 MID N069 3.18e-18
Gb2 MID N061 N060 MID 1
R65 N061 MID R_NOISELESS 1
R66 N061 N062 R_NOISELESS 1e8
R70 N062 MID R_NOISELESS 502.5e3
C25 N062 N061 3.18e-18
R73 N067 MID R_NOISELESS 1
G13 MID N027 N026 MID 1
G14 MID N030 N031 MID 1
R74 MID N027 R_NOISELESS 1
R75 MID N030 R_NOISELESS 1
S2 VCC ESDn ESDn VCC ESD_SW
S3 VCC ESDp ESDp VCC ESD_SW
S4 ESDn VEE VEE ESDn ESD_SW
S5 ESDp VEE VEE ESDp ESD_SW
S10 ESDp ESDn ESDn ESDp BB_SW
S11 ESDn ESDp ESDp ESDn BB_SW
G16 0 VCC_B VCC 0 1
G17 0 VEE_B VEE 0 1
R76 VCC_B 0 R_NOISELESS 1
R77 VEE_B 0 R_NOISELESS 1
G18 MID N064 N048 MID 1e-6
R79 N064 MID R_NOISELESS 1e6
G19 MID N065 N064 MID 1e-6
R80 N065 MID R_NOISELESS 1e6
C26 N064 MID 8.842e-16
C29 N065 MID 8.842e-16
C30 N066 MID 5.305e-16
RMID N063 MID R_NOISELESS 1e-2
.ends OPA1678
.subckt VOS_DRIFT_OPA1678 VOS+ VOS-
.param DC = 496.4e-6
.param POL = 1
.param DRIFT = 2E-06
E1 VOS+ VOS- VALUE={DC+POL*DRIFT*(TEMP-27)}
.ends
.subckt CLAMP_AMP_HI_OPA1678 VC+ VC- VIN COM VO+ VO-
.param G=10
GVo+ COM Vo+ Value = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
GVo- COM Vo- Value = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
.ends CLAMP_AMP_HI_OPA1678
.subckt OL_SENSE_OPA1678 1   2  3  4
GSW+ 1 2 Value = {IF((V(3,1)>10e-3 | V(4,1)>10e-3),1,0)}
.ends OL_SENSE_OPA1678
.subckt VCCS_EXT_LIM_OPA1678 VIN+ VIN- IOUT- IOUT+ VP+ VP-
.param Gain = 1
G1 IOUT+ IOUT- VALUE={LIMIT(Gain*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
.ends VCCS_EXT_LIM_OPA1678
.subckt VCCS_LIM_3_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 1
.param Ipos = 0.226
.param Ineg = -0.226
G1 IOUT+ IOUT- VALUE={LIMIT(Gain*V(VC+,VC-),Ineg,Ipos)}
.ends VCCS_LIM_3_OPA1678
.subckt VCCS_LIM_4_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 1
.param Ipos = 0.452
.param Ineg = -0.452
.ends VCCS_LIM_4_OPA1678
.subckt VCCS_LIM_CLAWp_OPA1678 VC+ VC- IOUT+ IOUT-
G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} =
+(0, 0.8E-3)
+(30, 2.22e-3)
+(48, 3.93e-3)
+(49.6, 7.2e-3)
+(50.4, 1.8e-2)
.ends VCCS_LIM_CLAWp_OPA1678
.subckt VCCS_LIM_CLAWn_OPA1678 VC+ VC- IOUT+ IOUT-
+(0, 0.8E-3)
+(35.2, 3.41e-3)
+(36.8, 5.2e-3)
+(38, 1.8e-2)
.ends VCCS_LIM_CLAWn_OPA1678
.subckt VCCS_LIM_IQ_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 1e-3
G1 IOUT+ IOUT- VALUE={IF( (V(VC+,VC-)<=0),0,Gain*V(VC+,VC-) )}
.ends VCCS_LIM_IQ_OPA1678
.subckt VNSE_OPA1678 1 2
.param FLW=1
.param GLF=0.1048
.param RNV=18.0086
.model DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
.ends VNSE_OPA1678
.subckt CLAMP_AMP_LO_OPA1678 VC+ VC- VIN COM VO+ VO-
.param G=1
.ends CLAMP_AMP_LO_OPA1678
.subckt VCCS_LIM_GR_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 1
.param Ipos = 0.326
.param Ineg = -0.326
.ends VCCS_LIM_GR_OPA1678
.subckt VCCS_LIM_1_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 1e-4
.param Ipos = .5
.param Ineg = -.5
.ends VCCS_LIM_1_OPA1678
.subckt VCCS_LIM_2_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 20.36e-3
.param Ipos = 0.163
.param Ineg = -0.163
.ends VCCS_LIM_2_OPA1678
.subckt VCCS_LIM_ZO_OPA1678 VC+ VC- IOUT+ IOUT-
.param Gain = 200
.param Ipos = 14.5e3
.param Ineg = -14.5e3
.ends VCCS_LIM_ZO_OPA1678
.subckt FEMT_OPA1678 1 2
.param NVRF=3
.param RNVF={1.184*PWR(NVRF,2)}
E1 3 0 5 0 10
R1 5 0 {RNVF}
R2 5 0 {RNVF}
G1 1 2 3 0 1e-6
.ends FEMT_OPA1678
    \$\begingroup\$ Please use the code, or <pre> and </pre> when pasting code. For some reason, tha last piece seems to big for the intepreter, and it won't be properly presented as code. Maybe it's a limitation in the site. \$\endgroup\$ Apr 4, 2020 at 10:54
  • \$\begingroup\$ The models run just fine for me. Be sure to not use the X prefix when using a .model, and vice-versa. I just copy-pasted the code straight from the editing of your question (because the last big chunk just won't appear correctly displayed as code). \$\endgroup\$ Apr 4, 2020 at 11:01
The sections that you say are improper look fine to me. However, these are models and not subcircuits.
A model provides parameters (constants) that will be used in a set of equations that are already built-in to the simulator.
A subcircuit is a collection of more primitive components that are connected together.
