I am trying to program with the PIC18F4550 a PWM with which I can regulate the duty-cycle with a variable resistance.
I attach my code to explain the problem I have.
#pragma config CPUDIV = OSC1_PLL2
#pragma config USBDIV = 1
#pragma config FOSC = HS
#pragma config FCMEN = OFF
#pragma config IESO = OFF
#pragma config PWRT = OFF
#pragma config BOR = OFF
#pragma config BORV = 3
#pragma config VREGEN = OFF
#pragma config WDT = OFF
#pragma config WDTPS = 32768
#pragma config CCP2MX = ON
#pragma config PBADEN = ON
#pragma config LPT1OSC = OFF
#pragma config MCLRE = ON
#pragma config STVREN = ON
#pragma config LVP = ON
#pragma config ICPRT = OFF
#pragma config XINST = OFF
#pragma config CP0 = OFF
#pragma config CP1 = OFF
#pragma config CP2 = OFF
#pragma config CP3 = OFF
#pragma config CPB = OFF
#pragma config CPD = OFF
#pragma config WRT0 = OFF
#pragma config WRT1 = OFF
#pragma config WRT2 = OFF
#pragma config WRT3 = OFF
#pragma config WRTC = OFF
#pragma config WRTB = OFF
#pragma config WRTD = OFF
#pragma config EBTR0 = OFF
#pragma config EBTR1 = OFF
#pragma config EBTR2 = OFF
#pragma config EBTR3 = OFF
#pragma config EBTRB = OFF
#include <xc.h>
#define _XTAL_FREQ 20000000L
void ADC_Initialize()
    ADCON1bits.PCFG = 0;
    ADCON1bits.VCFG = 0;
    ADCON0 = 0;
    ADCON2bits.ACQT = 3;
    ADCON2bits.ADCS = 5;
    ADCON2bits.ADFM = 1;
    ADCON0bits.ADON = 1;
unsigned int ADC_Read(unsigned char channel)
  ADCON0 &= 0x11000101;
  ADCON0 |= channel<<3;
  __delay_ms(2);
  GO_nDONE = 1;
  while(GO_nDONE);
  return ((ADRESH<<8)+ADRESL);
#define TMR2PRESCALE 16
long PWM_freq = 8000;
void PWM_Initialize()
    PR2 = 0x26;
    CCPR1L = 1;
    TRISCbits.RC1 = 0;
    TRISCbits.RC2 = 0;
    T2CON = 0x03;
    CCP1CON = 0x0C;
    TMR2 = 0;
    T2CONbits.TMR2ON = 1;
void PWM_Duty(unsigned int duty)
  if(duty<1023)
    duty = ((float)duty/1023)*(_XTAL_FREQ/(PWM_freq*TMR2PRESCALE));
    CCPR1L = duty>>2;
void main()
  int adc_value;
  TRISC = 0;
  TRISA = 1;
  TRISD = 0;
  ADC_Initialize();
  PWM_Initialize();
  do
    adc_value = ADC_Read(4);
    PWM_Duty(adc_value);
    __delay_ms(50);
  }while(1);
If I execute the above code, what I have at the output of the PWM are 0v and a frequency 0. As shown in the following image
If in the fixed code the value of the PWM Duty (580), for example.
Then I stop running the analog input.
So it seems that the PWM signal is regulated and I have a voltage at the output.
As I show in the following image.
What I do not understand is that in neither of the 2 cases the frequency is 0, when it should be approximately 8000Hz.
On the other hand I see that if I set the duty_cycle it seems that it regulates and gives voltage to the output.
So there must be a fault in the part of the analog input that I have not been able to find.
Finally, I leave a picture of the circuit.
    \$\begingroup\$ PR = 0x26 that don't make any sense for me. Another case: Why the cast to float? \$\endgroup\$
    – Mike
    Apr 3, 2020 at 9:44
  • \$\begingroup\$ Is the result of the calculation: PWM periodo = (PR2 + 1)*4*Tosc*Prescaler -> 1/8KHz = (PR2 + 1)*4*(1/20MHZ)*16 -> PR2 + 1 = 39.06 -> PR2 = 38.06 = 38 -> 26 hex -> PR = 0x26 \$\endgroup\$
    – Geo
    Apr 3, 2020 at 9:49
  • \$\begingroup\$ I have tried with the parameter PR2 = 0x3FF and the same thing happens \$\endgroup\$
    – Geo
    Apr 3, 2020 at 20:25
    \$\begingroup\$ duty = ((float)duty/1023)*(_XTAL_FREQ/(PWM_freq*TMR2PRESCALE)); This part is also wrong. Just CCPR1L = duty>>2;.Have a look into the datasheet. \$\endgroup\$
    – Mike
    Apr 6, 2020 at 5:14
  • \$\begingroup\$ Thanks for the help. I have already got it working. Apart from the errors mentioned above I also found this ADC_Read (0). \$\endgroup\$
    – Geo
    Apr 6, 2020 at 18:36
With the following code I could make it work
   PR2 = ("%#x", (_XTAL_FREQ/(PWM_freq*4*TMR2PRESCALE)) - 1); //Setting the PR2 formulae using Datasheet
   CCPR1L = 0x1F;
   TRISCbits.RC1 = 0;
   TRISCbits.RC2 = 0;
   T2CON = 0x03;
   CCP1CON = 0x0C;
   TMR2 = 0;
  if(duty < 1023)
      CCPR1L = duty>>2;
   ADCON0 = 0;
unsigned int ADC_Read(unsigned char ch)
   if(ch > 13)return 0;
   ADCON0 = 0;
   ADCON0 = (ch<<2);
   ADCON0bits.GO_DONE = 1;
   while(ADCON0bits.GO_DONE == 1);
   ADCON0bits.ADON = 0;
   return ADRES;
void main()
   int adc_value;
   TRISC = 0;
   TRISA = 1;
   TRISD = 0;
   ADC_Initialize();
   PWM_Initialize();
   do
       adc_value = ADC_Read(0);
       __delay_ms(50);
   while(1); //Infinite Loop
