]2
I am trying to model the cutoff mode of an NPN transistor with a switch that is connected to the base. Unfortunately, it shows current going through. I am using ORCAD Capture.
Does anyone know how to fix this? I should see zero current from the connector to the emitter.
I really don't know how the switch works in PSPICE. From what I found on the internet the symbol means that it opens at time t. Where should I define the time t? I googled and couldn't find an answer. The name of the switch is sw_tOpen and can be found in ANL_MISC library.
