See the current transformer below. Primary to secondary turns ratio is 1000:1, and Test winding to secondary turns ratio is 1:1. The burden resistor across the secondary is 10 ohms. I'm trying to produce a 60Hz AC current for the test winding. This winding is only used when one wants to test the proper functioning of the secondary circuit. The resistance of both the test and secondary winding is 80 ohms.
As the ratio between test and secondary winding is 1:1, I would happy producing just 1 mA current. But I'm not sure how to do this from a 3.3V microcontroller.
The idea I have is to generate a square wave from the micro, and feed that to an amplifier as shown below. I think I don't need that amplifier though, because I only need 1 mA. The switch S4 is an analog switch to open the test winding when not testing. C8 is the coupling cap, and L3 would limit the current provided that it has higher impedance than the test coil.
Do you think this approach is okay? Can it be simplified by removing the amplifier? How do I choose the components to ensure 1 mA through the test coil?
