I thought I'd see a PWM rectangular wave at opamp output, but the simulation gives a constant +Vsat.
Why am I not getting PWM ?
EDIT: After fixing VEE error pointed out by Transistor, still not getting the clean PWM output:(
EDIT: changing opamp to TL072 as suggested by G36 in the comments fixed the issue:
    \$\begingroup\$ Slew rate is the answer. And try to use a Comparator instead of an opamp. \$\endgroup\$
    – G36
    Apr 5, 2020 at 10:06
    \$\begingroup\$ ..... assuming you got the power rails correct muhuhahaha \$\endgroup\$
    Apr 5, 2020 at 10:15
    \$\begingroup\$ change to TL072 \$\endgroup\$
    – G36
    Apr 5, 2020 at 10:20
    \$\begingroup\$ An LM324 isn't man enough for 10 kHz. \$\endgroup\$
    Apr 5, 2020 at 10:25
    \$\begingroup\$ The LM324 is, by comparison, infinitely better than the 741. \$\endgroup\$
    Apr 5, 2020 at 10:51
Figure 1. Neatly tucked away under the VEE label is a -15 V parameter on the V2 supply.
The - terminal of a -15 V supply is +15 V. You have powered the op-amp with two +15 V supplies.
Switch it to +15 V.
  • \$\begingroup\$ good eye:) I played with optimally positioning both supplies and messed up haha \$\endgroup\$
    – across
    Apr 5, 2020 at 10:32
