I have eight different kV motors that I need to run from the same source. I cannot change the topology to have different sources for each motor. Ideally something that simply turns the relays on one at a time for five minutes at a time would be fine. I need to ensure with a degree of certainty that:
  1. Two or more motors cannot be run at the same time
  2. Between switching motors there should be a small dead time.
I cannot use a cheap (/chinese) relay board controller but it needs to come from a reputable supplier. I have read alot about using two contactors to INTERLOCK a motor to go forward and reverse but cannot find a way to daisy chain them. However the word interlock is defined for two devices, so it might be that I am missing the correct terminology to find the component.
Does anyone know of any topologies, hierarchies or components that could resolve this for me?
    \$\begingroup\$ What's a kV motor? \$\endgroup\$ – Marko Buršič Apr 6 at 19:03
  • \$\begingroup\$ A motor that requires a 1.5kV supply \$\endgroup\$ – JiPecki Apr 7 at 5:57
First, I would use a proper industrial PLC (Programmable Logic Controller) from a reputable supplier, not a board-level device from any supplier of any pedigree.
Secondly, you can simply daisy-chain relay normally-closed contacts to create an additional hardware interlock.
| improve this answer | |
Using industrial power contactors with add-on contacts, you can prevent to start more than one motor at once, this is fairly simple relay logics.
There are also pneumatic timers, for those contactors. They are expensive, but I have never seen anything more robust than those timers.
You should describe more in detail, what you need. Perhaps you will need also motor protection circuit, perhaps a small PLC like Siemens LOGO if you need a software interlock and timer, perhaps some kind of start/stop switch,...
