I am designing a circuit and needs to place some pull downs on the address pins of PCA9546 and usually my go to resistor values for these kind of situations is either 10k ohms or 100k ohms. These values work almost all the time.
Having said that, I thought that if I were designing this circuit where power consumption is critical surely the datasheet must have some information that tells me the maximum pull - up / down. But I could not find such information on the datasheet.
What section of the datasheet does information belong? If the IC that I have given does not have this information (considering its not meant for low-power applications) can you give an example datasheet that has this information?
