I'm trying to replace these two varistors from my maytag dryer. I'm not quite sure what party they are. They look like epcos/tdk brand but not sure what the s20 k275 11 08 means, Or the other symbols. Any help is appreciated.
varistors
S20K275, you can find the datasheet here: SIOV metal oxide varistors | EPCOS/TDK
You might have to order an equivalent from some other manufacturer but you should be set. MOVs have largely equivalent ratings, pick equal or better from the parameters in the datasheet.
Those parts look OK, are you sure they are bad? MOVs typically fail shorted (then catastrophically thereafter).
  • \$\begingroup\$ These are varistors, not thermistors. They should NOT change value with temperature! \$\endgroup\$ Commented Apr 6, 2020 at 21:17
  • \$\begingroup\$ Thanks! They look okay, but when I test them there’s no measurement. I’ve tested all other related parts of the dryer and they’re in working order \$\endgroup\$
    – Red
    Commented Apr 7, 2020 at 21:05
